Results 1 to 19 of 19
Like Tree19Likes
  • 2 Post By flashpixx
  • 1 Post By Sullo
  • 1 Post By level3ninja
  • 1 Post By robusto
  • 3 Post By Barry O'Speedwagon
  • 3 Post By LeroyC
  • 1 Post By LeroyC
  • 2 Post By noonar
  • 3 Post By Dimal
Thread: Naked Pour Critique Please
    Senior Member flashpixx's Avatar
    Dec 2013
    Perth Western Australia
    253
    I have no idea if this is just OK, acceptable, or better?
    There are no squirts of water or worse.
    Is the slow coming together of the pour into a single flow a sign of less than ideal distribution and tamping?
    https://youtu.be/uNYTnbgTsWM
    matth3wh and Sullo like this.
    Senior Member Sullo's Avatar
    Apr 2007
    Earth Sth Hemisphere
    1,156
    Looking good im no expert but id be happy ����
    flashpixx likes this.
    Feb 2005
    2,903
    Pour is good, but the colour looks off maybe. A tad on the brown side rather than reddish.
    Dec 2013
    253
    Quote Originally Posted by robusto View Post
    Great, thanks. What might cause that?
    Nov 2013
    1,640
    The beading is very even, every so slightly doughnut like (outside first) but better than mine! There is a slight dead spot in the centre to begin with, but it comes together reasonably quickly. If it happens every time you could look at your distribution but as a one off its nothing to write home about. I think the colouring is due to less lighting upward on the bottom of the basket, so the shadow is causing some slightly off colour rendering. All in all no obvious flaws, it's about the trends from here out.
    Feb 2005
    2,903
    Haha. So many variables including too hot. Roast profile. Bean variety.
    Dec 2013
    253
    Thanks for the comments. Yeah the lighting is a bit off.
    Seems I'm on the right tram with my prep
    Dec 2011
    PRL
    2,687
    Damn, I read the thread title and thought 'this could be a bit exciting', only to have my hopes dashed on viewing the video.
    GrahamK, flashpixx and Owlee like this.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,293
    1. Grind finer.
    2. Do everything else the same.
    Dimal, level3ninja and flashpixx like this.
    Dec 2013
    253
    1. Grind finer.
    Roger will do extraction time is 29 sec for 36g so a finer grind wouldnt hurt
    Sep 2013
    2,293
    Quote Originally Posted by flashpixx View Post
    Hmmm, maybe not by much then, depends how it’s tasting. I wouldn’t want to extraction time to be much longer. Maybe 32sec at the most.
    Senior Member noonar's Avatar
    Aug 2013
    MortalCoil
    488
    From what point do your start timing? I counted from first beading and it's like 15secs, dont see the end of the shot in the video though, that's just counting in my head, so no way scientifically precise.
    Dec 2013
    253
    Quote Originally Posted by noonar View Post
    I always start the timer when I raise the lever, so timing includes pre-infusion +/- 8 sec. The vid has been edited to remove the "boring bits" at the start and end.
    NB a finer grind resulted in a 34 sec pour, darker colouring, and no perceptible change in taste (still excellent)
    Dimal and robusto like this.
    Aug 2013
    MortalCoil
    488
    Cool, all looks rather delicious to me, finer would be my preference too - subject to tasting of course.
    Dimal and flashpixx like this.
    Feb 2005
    2,903
    Flashpixx is spot on. Timing is from the moment you press a button, move a lever, turn on a switch --whatever sets the pump going.
    On my machine, I know I'm going to be in trouble if more than 8 seconds elapse before I see coffee dribbling out of the spout.
    Dec 2013
    253
    Thanks everyone for commenting and helping. really do appreciate the advice on here. Top forum, thanks to the members on here
    Jul 2012
    perth
    15
    Hello,
    Can someone critic my pour please. I can see some squinting 6 o'clock is it my tamping? It is a 21g basket, extraction pressure is approx 11. Machine lelit Victoria.
    https://youtu.be/Kat5zXSK_Sg
    17,094
    More detailed information about your preparation process, coffee type, roast depth, weight of coffee in the basket, brew ratio being aimed for... would all be helpful...
    Yes, you definitely have a dose/distribution problem going on and the brew pressure is a little high. Could be adjusted down using a blind basket to a reading of 9.5-10 Bar on your brew pressure gauge before you do anything else.
    noonar, level3ninja and flashpixx like this.
    Jul 2012
    perth
    15
    Thanks,
    I will check in again. I don't have any scale to measure the dose, just base on how high the filling level. Beans is roasted on 25th Oct. So if it still within 1 week of roasting.
    Anyone has any idea how to adjust the brew pressure on lelit Victoria?
