Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By Lyrebird
Thread: Removing algae from water tank
    Jul 2008
    68
    I have noticed a dark algal build-up in the plastic water tank of my Expobar Leva.
    What do people do to remove it, please?
    I use spring water with a calcium level of 2mg/l (Adelaide water has lots more than that!) so not worried about calcium scale, just the algae.
    Member tampinator's Avatar
    May 2017
    70
    Quote Originally Posted by chrisl View Post
    Hi Chris, have you tried using a descale solution or white vinegar mixed / water solution?
    How often do you clean your tank? Itís good practice to remove your tank once a week, empty it and give it a good wash.
    Hope this helps
    Jul 2004
    2,137
    I remove the tank every now and them and use a bottle brush to clean it.
    If it is beyond saving, a replacement shouldn't set you back more than $30-$50.
    Jun 2018
    625
    Kill the algae by soaking the tank in bleach. Rinse well and return the tank to service.
    If you just clean it without killing the algae, the algae will return quickly: the spring water you are using has nothing in it to deter algae (as opposed to mains water where the chlorine / chloramines will suppress algal growth in the tank).
    robusto and Yelta like this.
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    948
    I use Milton tablets and they are food safe. Rinse after use of the tablet and you are good to go
    Jul 2008
    68
    Smile Algae
    Thanks, all.
    I will try the Milton tablets and report back.
    Love this forum :-)
