Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By Yelta
  • 1 Post By JohnA
  • 1 Post By Dimal
Thread: Bottomless portafilter handle angle or straight
    Apr 2013
    10
    I would like to know how one tamps a bottomless portafilter. My normal handles are on an incline and am wondering whether it is difficult to tamp a filter which is like this. I noticed that where the handle meet the filter holder it protrudes so the portafliter will not sit flat.
    Is this an issue? I guess when I tamp I can tamp on the edge of the bench.
    Is there options for straight handles instead on the OEM inclined and if so which would be your preference?
    Apr 2013
    65
    I just tamp mine on top of the knock box cross bar thingy
    Dec 2009
    SYD
    611
    Quote Originally Posted by Rodels View Post
    There are, but you may have to change the whole portafilter, rather than just the handle. The "angle" is determined by the bolt connection on the portafilter body (ie: the round metal section that holds the finer basket. Switching the handle won't appreciably change the angle.
    A common way to tamp a bottomless portafilter is to tamp at the edge of the bench. There are tamping mats designed specifically for this purpose, with a "waterfall" edge that hangs off the bench.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,373
    I made this block up, does the job perfectly, there are also commercially made options.
    https://www.coffeeparts.com.au/acces...ing-mats-bases
    Dimal likes this.
    Apr 2013
    10
    Quote Originally Posted by herzog View Post
    I don't own one yet and I am wondering if I can get either straight or the inclined which is preferred. I am thinking the incline handle and getting a block or mat so when I tamp both my bottomless and spouted filter my technique are kept relatively the same.
    I made this block up.
    I see your handle is straight, are your OEM handles straight?
    Jun 2009
    Moonta SA.
    7,373
    Yes they are.
    Apr 2007
    415
    these are the handles i use and they work great with this tamping station.
    If just using a bottomless, you can just tamp on the bench top with a rubber mat to not put markings on the bench, it will sit perfectly straight and you dont need to change your handles to straight ones.
    Dimal likes this.
    17,589
    Ours is a very similar setup to John's above and has been in use for 12+ years...
    JohnA likes this.
