Results 1 to 5 of 5
Like Tree4Likes
  • 3 Post By flynnaus
  • 1 Post By level3ninja
Thread: Help with pour
    Dec 2011
    4
    Help with pour
    Hi - keen for any feedback on the pour in the video. This is a particularly bad pour, but even my better ones still have an aspect of coffee squirting out and areas in the portafilter where it doesnt come through after a while
    https://youtu.be/0nS_QPCuWq8
    Rancilio silvia
    Grind on about setting 3-4 of a rocky
    18g into a espresso parts filter basket
    Relatively light tamp
    40g of espresso out in about 30 seconds
    Appreciate any help you're able to offer!
    Paul
    May 2008
    4,275
    Distribution problem and a finer grind perhaps. You've been on CS for a while. Has this been a recent problem?
    Can we assume you are using fresh beans?
    Tell us about your grinder type and age. How old are the burrs?
    barlo, level3ninja and 69SIM like this.
    Nov 2013
    2,009
    You could try tamping a bit firmer, but grinding a bit finer and using a toothpick to break up all clumps will be the most help.
    flynnaus likes this.
    Sep 2013
    60
    This would be my tip too. I tamp fairly firm, 18g in 32-36 out in approx 25s on my Silvia with bottomless basket and it works a treat. Best of luck.
    May 2019
    3
    A naked helps with showing how well you are tamping. A levelling/distributing tool can help (though not essential IMHO) but makinng sure the grinds are as evenly distributed across the puck and that your tamp is super level will help with spurting. I use a "Push" tamper, I find it excellent for keeping the surface level.
