Results 1 to 10 of 10
Thread: bubbles in crema?
    ugotitbad
    bubbles in crema?
    can anybody help me with this problem? im not getting nice extraction and im not sure what the cause is. im getting alot of crema but its a bit dark and bubbly.. ive tried to adjust the grind but not really helping.. does anybody know why?
    btw the coffee is really fresh and the machine is clean
    thnx
    Senior Member Lovey's Avatar
    Apr 2005
    South Coast NSW
    841
    Re: bubbles in crema?
    Gday Ugotitbad,
    When you say that your coffee is fresh, how fresh do you mean?
    Coffee that is really fresh, very soon after roasting, can cause a lot of bubbles in the crema when the coffee is extracted.
    What sort of machine and grinder are you using? A bit more info and your problems can probably be solved.
    All the best,
    Steve
    ugotitbad
    im using coffico coffee and its about 4-5 days after roasting.. im using an Azkoyen Capriccio Automatic grinder and a san remo 2 group
    Apr 2006
    4,126
    That would sound fairly normal for a freshly roasted bean to me. Once you let your coffee sit for a moment or two, how much liquid do you end up with?
    And as for the crema being dark, well, that is what you want as well, IMO.
    Jul 2004
    106
    Overly dark crema and bubbles can both be caused by a machine that is running too hot.
    ugotitbad
    the crema is also dissipating quite quickly
    Nov 2006
    1,673
    Sometimes I have crema that dissipates quickly - usually when the beans are starting to get a bit older. Though if the beans are only 5 days post roast they may still have a lot od gas in them which will give you a large crema which settles pretty quickly once the gas dissipates.
    Also some bean varieties also tend to lose crema quickly too.
    Oct 2006
    102
    How does the coffee taste?
    Senior Member askthecoffeeguy's Avatar
    Oct 2006
    Preston, victoria, 3072
    817
    try the same coffee again a few days later its probably still degassing
    ugotitbad
    the coffee tastes ok its probly just a bit too fresh .. thanx for the responses
  1. Small Bubbles in Crema
    By rynnlic in forum General Coffee Related...
    Last Post: 7th July 2010, 06:23 PM
  2. Crema Sucks. Try removing the crema and doing a double blind test.
    By ezralimm in forum General Coffee Related...
    Last Post: 8th April 2010, 01:03 PM
  3. bubbles from crema oil?
    By dweeby_espresso in forum Milk Froth and Bubbles
    Last Post: 14th July 2009, 11:03 AM
  4. Headspace, crema bubbles and the cooling flush.
    By speleomike in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 31st January 2009, 09:31 AM
