Results 1 to 14 of 14
Thread: Is filtered water necessary for an espresso mach?
    Sep 2007
    48
    My new Silvia seems to need a lot of water when I am cleaning, flushing, purging it and of course making espresso. I live in Melbourne...so do I need to use a water filter for the Rancilio? If yes, any recommendations?
    3,498
    Re: Is filtered water necessary for an espresso ma
    maxymaxy1,
    Melbourne water is quite soft - one of the lowest for calcium and magnesium salts in Australia.
    You are probably quite safe using straight tap water. A water softener is always good insurance.... but really not essential in your location.
    Sep 2007
    48
    Thanks JavaB.
    I appreciate your experienced reply.
    Nov 2006
    259
    Hmm im glad someone else asked... I have been a little bit shy to enquire due to the "rain water" thread... :-[
    Should i be using filtered water or a softener? Im in Sydney and using sunbeams (EM6910/EM4800C) at home/work ::).
    Oct 2006
    102
    I figure that as the water makes up 98% (dont quote me) of the espresso, the better the water, the better the overall coffee that could be achieved.
    3,498
    Quote Originally Posted by NE14COFFEE link=1191228067/0#3 date=1191290572
    OK firstly Sydney water is relatively soft - but not as good as Melbourne water. Perth (where I live) and Adelaide are both very hard....
    Filtering water is all about improving the look and taste of the water...... If it isnt crystal clear and tasteless.... then filtering will improve that.... and the taste of the resultant coffee..... it "protects" the person!
    Softening removes the Calcium and Magnesium salts - these produce the scale when you heat the resultant "hard" water...... Softening protects the machine.
    There is only one combined filtering and softening solution - and that is a Britta jug. The problem with these cartridge filters is the softening component becomes exhausted well before it ceases to function as a filter (especially if the water is hard).
    Otherwise two seperate devices are required..... say an under sink filter and a water softening cartridge filter (disposable) or an ion exchange filter (rechargeable).
    Sydney water probably doesnt require softening - as long as you do regular descales of your machine (as per the manufacturers instructions).... but a softener reduces the need for this.
    10,496
    I use the Brita and my Expobar has a softener (ion exchange).
    Nov 2006
    259
    So whats the conclusion? Since a softener isnt essential... Should i buy a brita or just used filtered bottled water?
    The user manual instructions are for descale every 4-6 months.
    3,498
    NE14COFFEE,
    Bottled filtered water can be worse that tap water for your machine (but generally not you!!)
    It depends on how much dissolved calcium and magnesium the particular brand contains...... and both these elements are good - even essential - for the human body...... so they can quite easily be left in the water.... especially waters which are "filtered through ancient rocks" etc.....
    A friend of mine (a member of the British foreign service) whilst serving in Paris would only drink bottled water (didnt trust the local tap water).
    He drank quite a bit of water (was a health nut.... no coffee.... alcohol etc) but became quite ill..... The British medical officer attached to the embassy diagnosed his condition as a type of mineral poisoning- due to the vast amounts of minerals he was consuming from the "pure spring water"....
    He went back to tap water (very reluctantly) and his health returned....
    Bottled isnt always best (or even better).
    Senior Member Lizzie's Avatar
    Feb 2007
    Bridport, Tas
    1,151
    ;) if i was in your situation i would just use the Sydney tap water (or if you really want, use a cask/flagon of spring water) and buy a small ion-exchange water softener which pushes onto the water-feeder tube of your machine and sits in your tank. i bought mine from CosmoreX, site-sponsor, for next to nothing.
    it re-constitutes with kitchen salt and lasts for years. 8-)
    as far as your maintenance, keep it simple ;) and apply the "once" rule; backflush *with water once per day, backflush with detergent once per week, descale *& clean grouphead (under shower-screen etc) once per month.
    cheers,
    L :)
    10,496
    If you want to use filtered, the Brita works out cheaper than bottled.
    Sep 2006
    171
    Quote Originally Posted by NE14COFFEE link=1191228067/0#7 date=1191303036
    I would get a brita and/or a softener. Just because I am a little lazy and want that "too lazy to descale" buffer. Its probably time to descale soon :(
    Nov 2006
    259
    Well Brita it is. Thanks for all the advice everyone :)
    Oct 2007
    6
    As a Melbournian (and a greenie), i wanted to point out a few little things for you.
    1 - With the current water crisis, Its always a bonus to use pre-filtered water. Filtering water often makes it hydrate better in the metabolism, and decreases the amount you drink per day.
    2 - Water filters are a very economic and efficient way of monitoring how much water you consume per day. Most of them have a "litres filtered" readout. And with water restrictions, thats an important factor to consider.
    So with those two points in mind, getting a water filter should be a lifestyle choice, not just a coffee choice.
  1. Any thoughts on the Kitchenaid  ESPRESSO MACH
    By jackal05 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th April 2015, 03:03 PM
  2. Filtered Water
    By Ren in forum General Coffee Related...
    Last Post: 11th September 2006, 10:07 AM
  3. filtered water
    By mr_fox in forum Brewing Equipment (non-machine specific)
    Last Post: 4th July 2006, 05:22 PM
