Results 1 to 10 of 10
Thread: La Marzocco stepped double basket
    Apr 2008
    Brisbane
    5,113
    What is the optimum amount of coffee in grams required for the La Marzocco stepped double basket (This an original stepped basket not the no step copy)
    Its has replaced the original spec basket for my Bezzera Domus / E61 porta filter
    I weigh my coffee grounds and find that 14 grams is not enough to take into account the tamp, as the tamper bottoms out on the step collar leaving the coffee under tamped and causes quicker water flow
    I have experimented a little with 14 grams as a starting point - at 0.1 grams over at a time but it may take a while to find the sweet spot. Any help will speed up the process
    If anyone has one of these baskets you may be able to advise
    I just need to know what would be the optimum amount of extra grounds needed to get all the variables just right
    Currently drinking WOW blend from bean bay
    Many Thanks
    Koffee Kosmo
    Feb 2006
    2,334
    Re: La Marzocco stepped double basket
    18 grams minimum. The coffee when tamped should be just above the ridge. Not under...and not too much over either.
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by Wushoes - David S link=1212036472/0#1 date=1212038663
    Fantastic
    That gives me a starting point - will start at 18 grams and adjust as needed
    Now will that increase my extraction time
    Many thanks David for the advice
    10,496
    If you dont change the grind or tamp then the extra 4 grams should increase your extraction time.
    Apr 2008
    Brisbane
    5,113
    Thanks TG
    I am not going to change the grind or current beans untill the new Macap M4D grinder arrives
    I will add another 5 seconds on the timer or cut the flow when judged by eye
    Mar 2008
    437
    The LM basket fits wierd on the domobar PF......
    Hows the extraction ompared to the stock galatea baskets?
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by Gavin1 link=1212036472/0#5 date=1212040650
    Hows the extraction compared to the stock galatea baskets?
    Basket fits snug in the Galatea PF it goes on easy with a snap sound at the end, also basket roll fits in perfect on the raised lip just above the spring clip of the PF,
    however I need a spoon to remove from PF
    Still working on extraction but even my underdose was just on the plus (+) side of acceptable
    Mar 2008
    437
    With the VBM the basket sits a tad higher and the PF locks at 7 o clock. Might have to file down the sides.
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by Gavin1 link=1212036472/0#7 date=1212047904
    I suggest wet and dry sand paper on a flat board/surface rather than a file
    Apr 2008
    Brisbane
    5,113
    David you are a genius the sweet spot for my machine is between 18.3grams and 18.6 grams
    The shot I just pulled has taken me to heaven
    What can I say
    I am happy as a kid in a candy store *;D
    Koffee Kosmo
  1. Replies: 11
    Last Post: 15th January 2013, 10:15 PM
  2. Replies: 6
    Last Post: 25th December 2012, 12:02 PM
  3. La Marzocco double basket for Silvia
    By SimonC in forum Brewing Equipment (non-machine specific)
    Last Post: 21st December 2010, 11:47 AM
  4. La Marzocco double filter basket for Silvia
    By Avi in forum Brewing Equipment (non-machine specific)
    Last Post: 20th December 2005, 05:02 PM
