Results 1 to 18 of 18
Thread: Those one way valve bags
    Jun 2008
    14
    Hi,
    FIrst time coffee snob.
    I am wanting to get into roasting at home, I am just sourcing the materials.
    Do one of the site sponsors supply those one way valve bags??
    Aug 2007
    569
    Re: Those one way valve bags
    Hi
    Welcome to Coffeesnobs.
    You can get some from Andy in BeanBay under other stuff.
    Or if you want to buy a lot - get some from coffeeparts.
    Ben
    Feb 2008
    1,339
    Hi grigden and welcome to CS!
    You can purchase bags from either Coffee Parts or Coffee Snobs - Buy Green>Other
    Jun 2008
    14
    Thanks for the tip, thats great.
    Glynn
    sdg
    sdg is offline
    Mar 2008
    368
    There havent been any bags for sale in Coffee Snobs - Buy Green>Other for a while now...
    Jul 2007
    539
    I like the 250g bags from CoffeeParts. Their opening is wider than other bags, so I can fit my hand inside to wipe them out after use.
    Senior Member speleomike's Avatar
    Nov 2005
    923
    Hi all
    Yes I have a few wider bags (~ 15 x 21 cm) but found that the ones from here are taller and narrower and I dont like em as much. I think the narrow ones would be fine for putting under a spout that dispenses coffee beans at a shop but its harder to pour beans into them without a spout and harder to clean them. Id like the wider ones.
    Mike
    sdg
    sdg is offline
    Mar 2008
    368
    How do you clean the bags? I have a couple Ive been re-using -- was just wiping them out with a tissue each time. Then last week I did this, tipped my freshly roasted Mysore Nuggets in, had a sniff -- eeyoow -- stale coffee smell! Tip beans right back out again -- are they contaminated?? (sniff)
    Then I tried to wash the bag. With dishwashing liquid. Now Ive got a bag that smells of soap as well as stale coffee :(
    Not an advance, I feel...
    Nov 2005
    923
    Hi simone
    1. I rinse out with hot water to remove most of the old bean crap.
    2. Then add one drop of washing up detergent and fill with hot water from tap.
    3. Rinse around inside with washing up brush
    4. Leave soak for 1/2 h to give detergent time to get at all the oils
    5. Tip out and rinse well with water.
    6. Fill again with water and let soak for 1/2 h to get any traces of detergent into the water.
    7. Final rinse 3 or so times with warm water and let drain.
    Finally - if any bags smell a bit rancid from oil then ditch it.
    Eventually your bags will need to be ditched even with good washing after use. But youll lets lots of use from them.
    Mike
    sdg
    sdg is offline
    Mar 2008
    368
    Thanks Mike. I assume you mean to wash this way after each use, but once they start to smell bad-coffee bad, thats the end.
    Those coffee oils sure are tenacious!
    So Im going to end up with a collection of very fine zip-loc bags that are no good for storing coffee. Cant throwem out -- theyre still good (for something -- look they even hold water!) Aarrggh.
    Think Ill have to look into something more biodegradable, or at least recyclable! Old ice-cream containers, anyone?
    Nov 2005
    923
    Hi Simone
    Oh Yes! Wash it out after **each** use or the oils will go rancid.
    I get about several uses per bag.
    And yeah its a shame to throw them out and ecologically bad as they are not a recylable plastic :-(
    Mike
    10,496
    My hand is too big to fit into even the Coffee Parts ones for cleaning so Ive been lining them with cheap (generic brand) freezer bags.
    I throw these out when the beans are gone, leave the bag to air and put in a new one next time I use that bag.
    I rotate through several bags so that they have time for the airing.
    I think the ziplock will wear out eventually and occasionally I heat seal one bag when I roast a two week supply, especially if its been reused several times.
    I can only heat seal them so many times.
    Try the freezer bags; they are less then 0.01c each and extend the life of the valved bags to many, many uses.
    Nov 2005
    923
    Hey, very neat idea Thundergod :-)
    10,496
    Thanks.
    If you want to go one step further you can reuse the used freezer bag as a knockbox liner before it finally makes its way to the garbage bin.
    Feb 2007
    149
    TG> by the way, that is an awesome idea. Ive been doing the same thing and lining my one-way valve bags with freezer bags since I read it in one of your earlier posts. Works a treat and saves me a bundle with cleaning and buying more... thanks!
    10,496
    Youre welcome.
    This place is all about sharing information and ideas.
    Apr 2007
    1,687
    Isopropyl Alcohol.
    22a
    22a is offline
    Apr 2008
    94
    One thing Ive been trying to work through lately is that I cant find anyone in NZ who sells the bags individually, and the smallest quantity Ive found I can buy is 100 bags for $50. Im too skint to buy that many (it would take me about 2 years to use up), or buy beans from another roaster and use their bags. So I have a couple of questions:
    1. Does anyone know of a place in NZ where I can buy them individually (or in smaller quantities than 100)?
    And if not...
    2. Would any of the Kiwis on the boards be keen on organising a group purchase of, say, 100 between four or five of us and just splitting the costs?
  1. !!GONE!!: Used Valve Bags
    By dencar in forum SOLD
    Last Post: 5th April 2009, 04:58 PM
  2. Freshness - one way valve bags
    By Intellidepth in forum General Coffee Related...
    Last Post: 30th July 2008, 06:10 AM
  3. Valve Bags
    By Cooper in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 14th May 2008, 05:43 PM
  4. One Way Valve Bags Re-Used
    By Secksy in forum Roasted Bean Storage
    Last Post: 23rd January 2008, 08:12 PM
