Results 1 to 4 of 4
Thread: Help: Water Volumes for std vs ristretto
    May 2008
    437
    Hi anyone,
    I need to finish calibrating the work machine tomorrow (did a quick fix before the weekend).
    If I calibrate the normal coffee button so that the water volume is 30ml for a single shot, what water volume should I use for a ristretto? (the machine uses the same grammage for both shots).
    Thanks.
    Nov 2006
    1,077
    Re: Help: Water Volumes for std vs ristretto
    I would have thought about 20ml
    Feb 2006
    2,335
    well to program a machine, make sure you actually take in to account the saturation of water in the coffee. The best way to do it is to make espressos in the programming mode.
    May 2008
    437
    Thanks. Well see what happens at 7:30am at the office tomorrow ;D
  1. The question of shot volumes
    By brokenvase in forum General Coffee Related...
    Last Post: 5th September 2012, 09:41 AM
  2. Jura S9 Steamed vs Frothed volumes
    By Intellidepth in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 17th September 2010, 05:34 PM
  3. Bean cooler for large volumes
    By Humphrey in forum Roasters
    Last Post: 16th May 2009, 09:28 PM
  4. Volumes : Milk/Espresso
    By Intellidepth in forum General Coffee Related...
    Last Post: 21st July 2008, 02:07 PM
