Results 1 to 3 of 3
Thread: Water
    May 2008
    437
    Water
    I met up with an ex-cafe owner at a business conference recently, and he said the Brita filter I have on my domestic tap is insufficient on its own for filtering water for a coffee machine and there should be at least 3 types of filters.
    Im a home user, not a cafe, using an unplumbed VBM Super, pouring 3-5 double-shot coffees a day. Do I need to go to the extra effort?
    Can someone elaborate on the specifics please?
    14,665
    Re: Water
    Quote Originally Posted by Intellidepth link=1221688489/0#0 date=1221688488
    I disagree intellidepth,
    Assuming your cartridges are replaced regularly, the brita is more than adequate for home use as it filters and softens water. I replace mine every 80 litres. I believe that this is fine except in very hard water areas such as Adelaide.
    This regime and a similar use profile led to no visible scale in my machine after 3 years.
    Another excellent option for your style of machine is to purchase a resin cartridge water softener from Attilio (Cosmorex). These attach to the water inlet in your tank and can be replenished simply by soaking in a salt water every couple of weeks. They are inexpensive and will pay for themselves very rapidly.
    regards
    Mar 2008
    554
    Re: Water
    I have a VBM DS and use a blend of about 80% reverse osmosis and 20% brita water. 100% brita water can be fine, but it depends on the condition of the tap water being treated and the age of the Brita filter (how much water has been passed through it). I use that blend because our water here is VERY hard with a lot of calcium/lime. I suggest getting an inexpensive TDS meter (search eBay) as these are easy to use and are an excellent way to keep track of the effectiveness of the filter being used.
  1. Water treatment - Scale inhibitor Vs. water softner
    By prloring in forum General Coffee Related...
    Last Post: 11th February 2012, 09:04 AM
  2. Using hot water in water tank for improved temperature stability?
    By jsrenaud in forum Brewing Equipment (non-machine specific)
    Last Post: 4th July 2011, 03:16 PM
  3. Maintenance of water softener/filter on end of water intake pipe
    By andrew in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st March 2011, 12:53 AM
  4. Question about drawing water now that I have replaced the in tank water softner
    By barrel in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th August 2009, 09:43 PM
