Results 1 to 20 of 20
Thread: Cooling flush of a (HX) Heat Exchanger Machine
    Apr 2008
    Brisbane
    5,115
    In the last month I have been conducting experiments on the best technique to achieve a cooling flush of my Bezzera HX machine
    Two things needed to be achieved
    Most important this technique had to be easily repeatable
    Be able to tell the correct amount to cool with visual references
    I normally leave my Bezzera on for 18 hours a day
    It could be left unused from 1 hour to 5 hours between shots
    The cooling flush method that I have come to rely on was
    Method
    Place and lock PF with basket fitted but without coffee grinds on group head
    Place a container under PF spout to catch the scalding water
    Turn on to start cooling flush
    At the start you will see a bubbling gusher of water with steam escaping
    At the middle of the flush water will slow and settle bubbles will diminish
    At the last part of the flush the water trickle will resemble a coffee shot being pulled (this is your visual ref)
    Stop cooling flush at this point
    Times and water amount discharged will change dependent on how long the machine is idle
    I then start the grind and tamp procedure and pull the shot as normal
    The experiment was conducted using a Synesso filter basket and the standard Bezzera filter basket. I achieved a repeatable technique with visual references with both.
    Testers Required
    I would like CS members to test this method on there own HX machines to see if this method works for you as well as it did for me, and report back with your findings
    Many Thanks [smiley=dankk2.gif]
    Koffee Kosmo
    10,496
    Re: Cooling flush of a (HX) Heat Exchanger Machine
    I basically do the same except I flush just before locking in the pf because it doesnt take very long and then theres no time variable if my grind/tamp procedure timing varies slightly.
    Also I dont lock in the pf to flush or catch the water in a separate container as the drip tray on the Expobar is huge.
    Apr 2008
    Brisbane
    5,115
    Quote Originally Posted by Thundergod link=1224421706/0#1 date=1224422105
    Yea that was how I did my cooling flush
    I just wanted to develop an easy method for people that are unsure how to go about it
    Well the new method works and works well
    TG I value your opinion, please give it a try and tell us what you think?
    10,496
    I think there nothing wrong with how you are doing it.
    The slight difference to how I do it is negligible and would come down to personal preference.
    In fact, sometimes Ill give it a preliminary flush if its been idle for a long time becuase then I know Ill only get steam for a few seconds so it becomes more of a pre-routine thing.
    Then Ill start.
    Grind
    Dose
    Flush
    Shot
    Mar 2008
    120
    Quote Originally Posted by Koffee Kosmo link=1224421706/0#0 date=1224421706
    Method
    I wonder if you dry the PF basket before putting coffee in it, because otherwise its all moist. I am also pretty sure in this case you probably also need to take the basket out and dry the inside of PF...?
    or are you using another PF, not the one you use for coffee?
    Apr 2008
    Brisbane
    5,115
    Quote Originally Posted by chartres link=1224421706/0#4 date=1224463402
    Method
    Hi charters
    Just wipe dry the filter basket is all thats required
    Shake off any water from inside the PF
    Then grind,dose & pull shot
    No need to dismantle the PF to dry it (think of cafes making 100s of cups a day)
    Oct 2007
    793
    hey KK
    im wondering if it would still be pretty easy to water dance without the pf in place. i know what you mean by watching the wtare exit the spouts, but i do this without the pf in place, which works for me.
    this would save you from having to shake out all that excess water caught in the pf under the basket. theres usually a fair bit of water that gets stuck in my pf unless i shake it and angle the pf down and to one side to allow all that to escape...
    10,496
    Good point roknee; the spluttering is easy to see without a pf in place.
    Apr 2008
    Brisbane
    5,115
    Quote Originally Posted by roknee link=1224421706/0#6 date=1224476225
    hey KK
    Yes ronkee what you do is the accepted method
    I also did this and can continue to do
    However this was an experiment to see what results would come from a different method
    Just to see if it is workable as it is very accurate time and time again
    Shaking the PF dry is a small inconvenience
    May 2005
    1,958
    Hi KK,
    I think that this will kinda work with my machine, but the importer had the thermosyphon tricked out so that you dont have to futz around with it. I just do a tiny flush and go.
    A few seconds difference doesnt really seem to make much difference. In fact, for some reason, the temp doesnt really drop that much with a free flush. I made a pressurised basket that I use to pull blind shots to decrease the brew temperature.
    Luca
    Apr 2005
    1,176
    I think these techniques depend very much on the machine. For example, the Pav (La Pavoni Bar T2) doesnt bubble or splutter at all. I vary the flush time to suit the bean Im using. Generally darker roasts require longer flushes. For my lighter roasts like the PNG Wahgi, theres only a minor flush to purge the HX lines. In this machine setting the proper boiler pressure is most important, because you really cant flush them down too far.
    OTOH, with my previous Bezzera BZ35, after the water dance, each second flush resulted in a 2 degree drop (from memory) in brew temp (as measured with a thermofilter-type device.). This is probably closer to most home machines in operation due to the much smaller HX volume. However, Lucas machine seems to be a good example of how different these machines can behave.
    Mark.
    Apr 2008
    Brisbane
    5,115
    Yea Luca and Sparky
    You are both right in saying that it is machine dependent
    And what mods a particular machine has to make it operate differently to the norm
    So the conclusion so far is
    What works for me may not work for others
    Well it was worth a try donít you think
    Mar 2008
    120
    Quote Originally Posted by luca link=1224421706/0#9 date=1224561353
    Hi KK,
    I think that this will kinda work with my machine, but the importer had the thermosyphon tricked out so that you dont have to futz around with it. *I just do a tiny flush and go. *
    even if the machine was idle for few hours? just double checking... I have the same machine (Makin, that is) and its kind of nice to know that its that stable in temperature.
    Visually, however, it splatters for few seconds so I do a longer flush, usually... I guess its just "to be sure to be sure"
    May 2005
    1,958
    Quote Originally Posted by chartres link=1224421706/0#12 date=1224652512
    Hi KK,
    My machine stays on 24/7, which means that the machine might sit for 15 hours between shots. *Yes, yes; I know - I need to find my timer! *I have never needed to do more than a tiny flush, and I cant really remember it spluttering much ... it might do it a little; Ill have to check next time. *I must confess that I am pretty lazy in my standard flush routine; I treat the machine like a Marzocco and just do a small flush at some random time before brewing.
    I borrowed a scace device about six months ago and the results indicated that a longer flush was not required. *Indeed, I wonder if a flush is required at all. *In terms of measurements, I have only done testing on one afternoon and I have only tested my machine, so I cant personally confirm scace results for more than my particular machine. *The temperature was pretty much identical for shots pulled at a reasonable pace - ie. allowing time to grind, dose and tamp in between. *Shots pulled back to back were subsequently a degree or two cooler each time. *Thats how I came up with the pressurised portafilter idea for lowering brew temperature. *Im yet to get on the scace to confirm that it works.
    I descale my machine a few times a year and use a brita filter in addition to the standard filter, which I recharge every few months, so I doubt that there is scale slowing down the thermosyphon on my machine. *
    I remember that the tweaked thermosyphon was one of the things that Dave really wanted his machine to have and I did note that the machine had it when I was working at Veneziano and introduced the machine to the board. *From memory, at the time the only other domestic machines that I could find out online that had a similar setup were the Expobars. *So I have to confess that its a bit of a surprise to me that this seems to be news to you ... especially seeing as you have one of the machines. *I always thought that the lack of futzing around was a good selling point for it.
    I am currently drinking Coffee Supremes Supreme blend, so I have the pstat up a tiny bit higher than usual (1.3 bar). *I cant remember if I get some spluttering or not, but my technique is still just to flush for two seconds or so and not to worry about it too much. *I am currently drinking a very nice long black produced using this technique. *It is nice and rounded, with what might be an unpleasantly strong acidity at a lower temperature (like 1.1 bar) converted to a nice juicy quality.
    Could I ask what boiler pressure you are running?
    Luca
    Mar 2008
    120
    Quote Originally Posted by luca link=1224421706/0#13 date=1224653723
    [quote
    Luca
    Luca,
    I didnt change pstat setting from what was initially set. The gauge is showing approximately 1.1 (actually it almost like 1.05). I did notice that some blends were not particularly, well, at their full potential when I brew them, comparing to when I had them in cafe (if I did have chance to compare). However, all in all I am happy with how, for example, BBB espresso blend or Veneziano Concordia work for me...
    What I didnt do, I didnt compare shots with tiny and longer flushes... maybe I should do that. Is not that I have a lot of splattering, but the water flow from the group without p/f is definitely steadier after 10sec comparing to, say, 3sec flush
    How I bought the machine - its a different story, the one I bought initially wasnt this one, I had to return it and negotiate upgrade with the seller to the best available at the store. Which by several accounts was Maver Makin espresso. I never regretted that decision, though ;-) By the way, review at your blog was one of the opinions I took into account. Somehow you earned my trust with your posts here ;-)
    May 2005
    1,958
    Hi Chatres,
    I went down to the machine after it had sat idle for most of the day at 1.3 bar and it did sputter for the first few seconds of the cooling flush.
    On my machine, I would guess that 1.05 bar would work out to a relatively low brew temperature; like 90C or thereabouts. The BBB and Veneziano blends can hack at least two or three degrees higher than that. You might find that a higher pstat setting, like 1.2 bar at the top, works out a bit better for you. It would be remiss of me not to include the usual warnings - pstat adjustment is at your own risk, might void your warranty and if you arent careful, you might break your pstat or die from electrocution (unplug it!). I think that I will return to 1.2 bar shortly.
    Glad that my blog post was helpful. I really didnt want to write it, seeing as I was selling the machines at the time, but there was no decent information about the machine available and people kept on asking me questions.
    Flushing for a few seconds longer than you need wouldnt be much of a problem on my machine. Particularly if I were to do it before I ground the coffee.
    Luca
    Apr 2008
    32
    Ive tried this at home over the last couple of days after letting it heat up for a couple of hours. Seemed to work a treat! Although it has been unseasonably cool the last couple of days. I usually lock in my single pf though, it makes it easier to see the stream than a double. Ive tried observing the steam of water coming out of the head with no pf, but I find that its a little too random.
    I would usually flush between shots as well on a normal day on my BZ99s(normal day meaning hot in QLD), didnt have to today! Who would have thought a 15% increasing in cooling would make such a difference (studying for a thermodynamics exam ;)) I suppose the weather where you live plays a big roll.
    Apr 2008
    Brisbane
    5,115
    Thanks for the report Trev
    With all advice in coffee making pointing to a set routine is the key to good coffee
    I found that this technique is spot on every time and takes the guesswork out of the equation
    Keep those reports of your tests coming?
    May 2008
    600
    very machine dependent I think. On my old e61, pstat was at 1.1 and a flush wasnt necessary. but it probably was running a touch on the cold side. With teh rancilio at 1.1, I need a good flush (I have a botton programmed for a flush) or else coffee will be badly burnt. I suspect there is lots at play here - the group design, the hx size, the length of the thermosyphon lines, etc.
    Damian.
    Dec 2004
    Earth!
    15,925
    On my Cimbali M28 2 group if it has been idle for more then 5 minutes the regimen that Ive developed over the years is:
    • Flush until the hot water dance stops (8 seconds), plus 5 more seconds.
    • Weigh and grind coffee.
    • Flush until the hot water dance stops (5 seconds), plus 3 more seconds.
    • Dose and tamp.
    • Pull shot.
    The pf is removed for the flushing and then immediately put back on.
    This has worked very well for me with the setup I have and provides an easy and repeatable process.
    Java "Your mileage may vary" phile
  1. PIDing a heat exchanger machine
    By coffeeboy83 in forum General Coffee Related...
    Last Post: 17th October 2012, 01:07 PM
  2. Cooling Flush On A VBM Domobar Jnr?
    By JJJ in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 7th November 2011, 08:41 PM
  3. Cooling flush
    By jimmyb in forum Brewing Equipment (non-machine specific)
    Last Post: 31st May 2007, 12:33 PM
  4. Replies: 3
    Last Post: 14th May 2007, 01:25 PM
