Results 1 to 15 of 15
Thread: Uneven Pour
    Oct 2008
    Adelaide, South Australia, Australia
    27
    Uneven Pour
    Hi All
    I need help mastering my new Silvia and Rocky. No matter what i do with the grind, tamp etc, one cup always has more coffee than the other when i use the double group handle. I have a Pullman tamper which shows that my tamp is level. What can you suggest?
    Any feedback is appreciated as im new to all this.
    May 2005
    1,995
    Re: Uneven Pour
    Might be worth pulling out a spirit level to make sure that your machine is level.
    Apr 2007
    1,687
    Re: Uneven Pour
    From memory, Silvia PFs do that. I think I remember reading a few threads of people having to file down (oh, so slightly) the inner floor of the spout. If you do a search for the same thing I reckon youd find something about that.
    So it may not be you (but it may be) but the spout itself giving you the uneven pours. Oh and the spirit level doesnt hurt either.
    Jul 2007
    31
    Re: Uneven Pour
    Reading your post just now has made me realise that I no longer get uneven pours with my Silvia, it was obviously something that Id gotten so used to that Id stopped noticing!
    Thinking back, the pours started evening out at about the same time that I started roasting my own beans. I have made one or two other changes since as well, but Im pretty sure the beans were what made the difference.
    Oct 2008
    27
    Re: Uneven Pour
    yeah ive used all sorts of beans from a small roastery in Adelaide so i dont think that it is that. As for the pirit level? I built the kitchen so if is isnt level, id be shattered! ill check it out though. Im not wanting to file the PF though... sounds pretty harsh!
    Just checked the level and it is good. phew!
    Could it be the uneven way the grinds fall into the basket from the rocky?
    Apr 2007
    1,687
    Re: Uneven Pour
    Im almost certain its the spout, thats all. I dont think its a huge filing job.
    Whats your distribution method before you tamp?
    May 2007
    Perth, Western Australia
    3,174
    Re: Uneven Pour
    It is a common thing with the Silvia double spout, many posts have been made on this subject and most agree it is just the spout that produces an unneven pour. Simple solution, just drink doubles!!!! When I do two singles I just remove one cup and top up the other from both spouts near end of pour, or short change one unsuspecting person..................!!!!
    Oct 2008
    27
    Re: Uneven Pour
    Quote Originally Posted by YeeZa link=1224676758/0#5 date=1224715400
    i just tap the handle on the bench a few times then tamp. it looks fairly even before i tamp with a little mound in the middle. i have the tamp pretty level now and everything else seems to be symetrical
    if i do muck around with the spout (grind it down), how do i do it. Id almost preffer to just buy a replacement one.
    10,496
    Re: Uneven Pour
    You just need a really small file.
    You can get a set from a junk shop for a few dollars.
    The round profile would be my choice.
    Oct 2008
    27
    Re: Uneven Pour
    Will it corrode?
    Jul 2007
    2,288
    Re: Uneven Pour
    Put a coin or two under the feet on the side of the machine that over-fills, and tilt the machine a bit.
    Being level isnt everthing.
    OT--"How do you tell that an Aussie is on the level?"
    "He dribbles evenly out of both sides of his mouth!"
    Sep 2004
    136
    Re: Uneven Pour
    I noticed this a lot with my Botticelli and it was probably uneven tamping.
    Since upgrading to a Giotto the problem largely went away but seemed to return. Solution: clean the PF. Slackly I hadnt cleaned the insides of the PF since getting the Giotto some 3+ months ago, even though Id been weekly backflushing/cleaning it.
    The inside of the PF was horrible and once given a good clean, coffee poured out like never before - even and beautifully textured, just like it should.
    Oct 2008
    27
    Re: Uneven Pour
    it has been doing it from new so id say that it isnt a cleaning issue. ive only had it a week now. I have upgraded the basket to a 14g and it is a little better. 40ml out one side and 20ml the other. Ill keep mastering my process till it sorts it self out.
    Thanks everyone for their help.
    Scott.
    Mar 2008
    554
    Re: Uneven Pour
    To eliminate you as the factor causing this try the following:
    1 - temporarily remove the basket locking spring from the portafilter body
    2 - insert the basket and go about the task of pulling a shot (dose, tamp, etc.)
    3 - before locking the portafilter in place, gently turn the basket around 180 degrees in the portafilter.
    if the pour is still uneven, it aint you. It probably isnt a leveling problem either. It could be some flash in the portafilters opening at the bottom, or some mis-casting in the spout itself. You can easily remedy these problems with a small round file.
    Oct 2008
    27
    Re: Uneven Pour
    Quote Originally Posted by Randy G. link=1224676758/0#13 date=1224911839
    Well ive done this and it was still uneven. its not me. looks like ill be getting to it with a file. hmmm. makes me nervous.
  1. Rancilio Silvia uneven pour
    By steve_brown in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th December 2011, 02:42 PM
  2. Silvia uneven pour
    By philipmach in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th June 2011, 08:56 PM
  3. Giotto Premium - Uneven pour
    By cremachine in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 16th January 2010, 01:02 AM
