Results 1 to 5 of 5
Thread: 30 mls
    Jul 2008
    33
    30 mls
    hi this is one of my first post so please take it easy on me :)
    today when i hoped onto a coffee machine *i noticed that the pour was blonding for a long time before the machine stopped and was wondering for the 20-30 seconds for 30 mls rule would you say that it is including crema or without ?
    thanks for the help
    Jun 2006
    754
    Re: 30 mls
    Hello
    Welcome to CS! :)
    Are you using fresh beans? Stale beans blond earlier. If you dont put enough coffee in your portafilter that can also cause early blonding.
    For me I normally go for colour rather then the specific rule of 20-30sec for 30ml. I just use that as a guide line. Im fairly sure the 30ml is including crema.
    CK
    10,496
    Re: 30 mls
    Sounds like you just pressed a button.
    As CK said, fresh coffee is a must.
    I too go by colour.
    If I accidentally dosed a gram or two less it would blonde if I was pouring by water volume.
    I always pour using the manual button.
    If it blonded a LONG time before the pour ended it does sound like the beans werent fresh or the grind was too course.
    Jul 2008
    26
    Re: 30 mls
    or too fine, if your coffee is coming out in longer than 30 seconds then itll blonde before the 30 mls is up. especially in a double handle
    Jul 2007
    2,288
    Re: 30 mls
    It may also depend on how you drink your coffee. I like my straight ristrettos pulled earlier than ones that end up in a piccolo latte.
