Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By littleroundman
  • 1 Post By Barry_Duncan
Thread: Sex and coffee trigger stroke
    Dec 2004
    Earth!
    16,040
    Coffee, sex and blowing your nose could increase the risk of a type of stroke, say researchers in the Netherlands.
    The study on 250 patients identified eight risk factors linked to bleeding on the brain.
    They all increase blood pressure which could result in blood vessels bursting, according to research published in the journal Stroke...
    ...They found that coffee was responsible for more than one in 10 burst brain aneurysms.
    While people drinking coffee had only a 1.7 times greater risk, it is more common than other risk factors...
    Percentage of bursts due to:
    Coffee 10.6%
    Vigorous exercise 7.9%
    Nose blowing 5.4%
    Sex 4.3%
    Straining to defecate 3.6%
    Drinking cola 3.5%
    Being startled 2.7%
    Being angry 1.3%
    ...Dr Sharlin Ahmed, Research Liaison Officer at The Stroke Association said: "A sudden surge in high blood pressure can increase the likelihood of an aneurysm rupturing. However, its very difficult to determine whether the triggers identified in this study are definitely related to the onset of a stroke as they could simply be put down to coincidence.
    "A lot more research needs to be carried out to assess whether each of the identified triggers could directly cause an aneurysm to rupture."
    Full article: http://www.bbc.co.uk/news/health-13294022
    Source article: http://stroke.ahajournals.org/cgi/content/abstract/STROKEAHA.110.606558v1
    Java "Sippin on a cuppa" phile
    Sep 2008
    58
    Re: Sex and coffee trigger stroke
    Right,
    that does it,
    Im never blowing my nose again.
    SammyLee likes this.
    May 2007
    Perth, Western Australia
    3,167
    or get constipated!! :( :(
    10,496
    Is vigorous sex 7.9% + or x 4.3%?
    Senior Member sidewayss's Avatar
    Jun 2010
    Perth, Western Australia.
    1,434
    Sex?. Sex?? Whats that?
    Id be hard pressed to attempt all of the eight points to achieve approximate accumulated 36%.
    Surely more likely my fellow coffeesnobs will get an arnie...annie..ana..anal...aneurysm (whew,talk about vocal constipation :D) from burning a roast or messing up a perfect shot. Or worse still, running out of beans :-X Heaven forbid.
    Gary at G
    May 2010
    Sydney North Shore
    1,326
    For the good of my health I have given up vigorous exercise, blowing my nose and drinking cola.
    If the other things are accumulative, if I give up almost everything except coffee, I should stay healthy.
    Barry
    Parsimony likes this.
    Jun 2010
    1,434
    Easier said than done Barryd ;)
    Seven of those points have happened to me on the same day before, except for that sex thing part.
    It comes down to sensibilities. As long as its all done in moderation without overdoing it, the chances of a stroke is slimmer.
    Better to stick to 2-3 cups of coffee a day rather than more than 8 cups a day.
    Gary at G
    Senior Member caffeol's Avatar
    Jul 2008
    Brisbane
    130
    So Im guessing instant coffee counts as 10.6%. Therefore does simulated sex count as 4.3%? :-/ :)
    Nov 2010
    369
    I would want to do see the methodology just because 10.9% of people had consumed coffee before an event doesnít mean that this event had anything to do with whatever happened.
    If a large number of people were breathing just before they had a stroke would it mean that breathing somehow causes a stroke?
    After all I think the researcher would be unlikely to find someone who had not been breathing in the previous 5 minutes that had had a stoke.
    If coffee changes your blood pressure what sort of change does it cause and for how long?
    What about De-Caff?
    However I will confess I did have a cardiologist charge me over $500 once and all he said was donít eat liquorice. :-/
    Apr 2011
    9
    All in moderation
    Senior Membear Bean_Bear's Avatar
    Aug 2010
    Adelaide
    177
    I thought it was having a brain aneurysm that predisposed you to having a ruptured brain aneurysm?
    So if the thought of increased risk of bursting your pre-existing aneurysm whilst drink coffee during vigorous sex that involves strained defecation and nose blowing makes you angry, then avoid any sudden and unexpected consumption of cola type products.
    Remember that if you suddenly leave CoffeeSnobs without explanation we will assume that this is how you met your demise.
  1. Buy some of the worlds best coffee - and help a stroke victim.
    By Identity in forum General Coffee Related...
    Last Post: 12th February 2010, 08:01 PM
