Results 1 to 4 of 4
Thread: Question about Genecafe - Heat
    Apr 2005
    35
    I have roasted coffee on Genecafe 5 times already, and I am wondering whats actual temperture? is it the temperture in the "drum"? or the temperture from the heater? when I change the temperture, it increase/decrease so fast......
    Daniel
    Nov 2008
    62
    Re: Question about Genecafe - Heat
    I believe there are 2 sensors, one before the drum and one after.
    When I use a probe in the heatbox directly where the air goes into it, it reads some 20 degress cooler during heating and 10-20 degrees high when cooling down, which would indicate that the sensor being used is the one before the drum.
    The actual heat of the beans will be somewhat lower - would love to figure out how to measure that ...
    Apr 2005
    35
    hmm.......so which means the actual temperture isnt the temperture in the drum?
    Nov 2008
    62
    Behmor Coffee Roaster
    There are no sensors in the drum.
    The best roasters have sensors in the beans, measuring bean temp not environmental temp, and that is what people with correttos are referring to. That will read much lower than the environment (and ramp up slower as well).
    The Gene has the sensor at the source, so will show a higher temp on the way up, and maxing when the beans are still actually on their way up.
    You get used to it.
  1. Heat gun roasting - Airflow question
    By salt in forum Roasters
    Last Post: 28th April 2011, 06:20 PM
  2. Genecafe
    By Sullo in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 7th October 2007, 04:04 PM
  3. Heat Gun Volume Question
    By Robster in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 24th November 2005, 08:25 AM
