Results 1 to 2 of 2
Thread: My first roast
    Aug 2008
    4
    My first roast
    Greetings fellow coffeesnobers! *Well I finally sucked it up and put all the little parts together and sorted out my Corretto roster (pics to come). *Now I am not sure how it went, though I cant wait to try the beans! *I have a couple of questions as I am a bit worried it all went to quick and finished early. *
    The beans were the Guatemala Huehuetenango from the Nov beanbay, I started with 250g and ended with 202g (machine shot a few out the top)
    Here are the time and temp figures from the roast
    Time Temp
    0 24
    1 29
    2 81
    3 120
    4 143
    5 156
    6 164
    7 180
    8 190
    9 202 - First Crack
    10 195
    11 199
    12 206
    13 215
    14 188 - Second crack - backed temp off before checking the probe hence the 188c
    The beans cooled super quick in my Electrolux 337 bean cooler * ;) *(picks to follow)
    Does this look like a fairly acceptable roasting time & temp range? *I started with the heatgun slightly above rim of the bucket. *I raised a touch when the temp went up significantly at the start to stabilise it a bit and then backed it up some more to try and hold @ around 200.
    If these times are a bit quick what should i be aiming at to be right in the sweet spot?
    All in all I am pretty happy with the how it went, it went a lot more smoothly than i expected (i had expected to cremate the beans). I will update once I have made a cup or two out of them.
    Thanks to everyone for all their very informative posts that helped me get going!
    May 2007
    Perth, Western Australia
    3,167
    Re: My first roast
    Behmor Coffee Roaster
    Congrats on your first Corretto roast, it should taste pretty good. Most roasters try for [s]second[/s] first crack around 11-13minute mark and then second 5-6 mins after that, its just a matter of getting into a routine and knowing the signs of different stages of the roast, its all great fun and a learning experience, enjoy the journey......................gm
  1. Replies: 81
    Last Post: 6th September 2013, 09:36 AM
  2. Cafe Startup Question: Self-Roast or Outsource Roast?
    By mirx in forum General Coffee Related...
    Last Post: 30th May 2011, 12:14 PM
  3. size of roast effects on  Gene Cafe roast tim
    By herbie in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st April 2007, 09:30 PM
  4. single roast...3/4 roast...double roast
    By lucinda in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 5th January 2007, 03:47 PM
