Results 1 to 5 of 5
Thread: Another Corretto Rig...
    Dec 2008
    149
    Nothing really new here - but thought Id share some pics of my Corretto rig!
    Specs:
    Bread Machine: Breville BB290, on Dough Cycle
    Heat Gun: Bosch PHG 630 DCE, digital control 50-630deg, 2000W
    DMM: Jaycar Digitech QM-1526 - with thermo probe.
    Cooling: Large 60cm Mistral Fan from BigW
    Completed Roasts: About 30x580g Batches (about 500g after roasting) - perfect fit for my valve bags.
    The trimmed down guitar stand has been great, this in conjunction with my bread machine stand (2 old touch screen stands and a piece of pine) gives unlimited adjustment. Ive found all this adjustment a bit overkill, the digital heatgun allows me to fine tune the temperature, I rarely have to adjust the height.
    I suck the chaff out into the yard by placing the fan in front of the roast. I then flip the fan over to cool the beans! *The advantage Ive found in sucking the chaff over blowing it, is that it doesnt really affect the performance of the heat gun.
    Im on my second thermo probe - the first one got smacked by the paddle on each revolution, so it didnt last long. I relocated the second one to the corner, clear of the paddle!!
    Cooling method is basically me physically shaking the hot beans over the fan, it works ok - one day Ill build a bucket cooler I can just drop them in to!
    Pics...
    When I next do a roast (hopefully in a day or two) Ill take some action shots!
    May 2008
    4,211
    Re: Another Corretto Rig...
    Thanks Peter
    I see what you mean by the fan now. I was thinking bathroom/kitchen type exhaust fan. The venturi effect for sucking the chaff rather than blowing is a good idea.
    I like the weight on the guitar stand. Obviously for stability but one might also think that the Bosch HG develops that much thrust, it helps prevent lift-off :D
    Where did you get the mesh basket from
    Dec 2008
    149
    With the bread machine vibrating and the weight of the HG - it helps keep things steady!!
    I picked up the mesh baskets from one of those $2 variety shops. They really arent that good - I cable-tied them together to form an enclosure, but they arent formed well, and sometimes a bean or two will escape through the crack and you have to shut your eyes while the fan ricochets them all over the place!!
    May 2007
    Perth, Western Australia
    3,169
    Nice work Peter, good to see another Corretto in production!!
    Just did a roast of El Salvador and used your spreadsheet, it worked a treat, I managed to stick to my profile line fairly well, will be using this in future, thanks for making it available..................gm
    Dec 2008
    149
    Behmor Coffee Roaster
    excellent - glad it was useful!
  1. How do YOU Corretto?
    By kabintylen in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 31st July 2009, 06:53 PM
  2. PID Corretto MKII or Pimp my Corretto
    By wrstikoff in forum Roasters
    Last Post: 4th November 2008, 09:39 AM
  3. Corretto
    By Gra in forum Roasters
    Last Post: 15th September 2008, 06:58 PM
  4. Best BM for a Corretto?
    By beanz4brainz in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 29th November 2007, 01:26 PM
