Results 1 to 9 of 9
Thread: Where to start??
    Mar 2009
    Redlands,Queensland
    652
    Where to start??
    Newbie here, been in coffee a little while but now interested in roasting. Where do I start had a look @ a iRoster today quickly do I need something like that or can use oven or something else?? How much would u roast each time etc.
    Just need info about it before I continue down this path of roasting, I love the idea of fresh roasted beans the smell and taste.
    Thanks all!!
    Apr 2008
    Brisbane
    5,115
    Re: Where to start??
    Go to this link and have a look at the Important topics at the top
    Have a good read as just about all roast methods are covered
    Such as Off the shelf units & Home made roasters
    It all depends on your budget and your expected capacity or amount you want to roast
    I believe the I roast has a capacity of 250gr of green beans
    Go and have a read as a starting point - the I Roast is also reviewed *;)
    http://coffeesnobs.com.au/YaBB.pl?board=roasters
    Jul 2008
    Port Fairy
    2,993
    Hi,
    I started with a Stainless Steel bowl, Heat Gun and a Wooden Spoon :) The first couple of roasts were done without a temperature meter but one quickly followed.
    If you want to have a play try that option even if you beg borrow or steal someone elses heat gun and grab a Starter Pack from Beanbay. No $$ entry apart from the beans.
    You cant use an oven as the beans give off smoke and chaff (like the outside of peanuts), not to mention the fire risk if it is a gas one.
    I went down the path of a second hand Hottop but a Corretto/Bread Maker is a cheaper option.
    Also where in Oz are you and you might be able to find a fellow coffeesnob that roasts to go and have a look at their setup?
    Be warned Roasting is as addictive as Caffeine :D
    May 2008
    98
    Youre a Brisbo right? What suburb?
    Why dont you go down to Veneziano and use their awesome Geisen 1KG roaster, probably the cheapest way to start off and a great way to get some coaching from a roasting legend (Peter "Wolfman "Wolff, he is truly inspirational).
    Check out their wesbiste re Roast your own
    May 2007
    Perth, Western Australia
    3,169
    Hi mmmcoffee, I started with a popper and graduated to the Corretto, you can set one up for minimal cost if you scout around for the gear from friends and op shops, it does a fantastic job, heaps of information from fellow roasters to get you on your way, I usually roast 600g at a time which gives me 500g of roasted beans. With a thermocouple to monitor your temperatures its easy to follow roast profiles to a particular beans requirements.
    Jump in and build one you wont regret it.
    Mar 2009
    Redlands,Queensland
    652
    hey guys thanks for your help, I love in Cleveland Queensland. have been meaning to pop into Veneziano to check it out.
    thanks!! :D :D
    Jul 2007
    Werribee, Victoria, Australia
    737
    You could start with a popper, I know I did.
    Dec 2007
    63
    Quote Originally Posted by 5B5B5B555950505353360 link=1238506231/5#5 date=1238581912
    Does that mean you live fairly close to there as well? *[smiley=evil.gif]
    Feb 2008
    48
    Behmor Coffee Roaster
    Or maybe he moved there from New Zuland!
  1. Replies: 0
    Last Post: 30th May 2012, 05:29 PM
  2. Where to start???
    By zacmac in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th October 2011, 09:37 AM
  3. where oh where to start?
    By bamboogal in forum Brewing Equipment (non-machine specific)
    Last Post: 27th July 2007, 01:46 PM
