Results 1 to 5 of 5
Thread: Heatgun Vs Portable Electric Hotplate
    Mar 2009
    43
    Hi guys, im in the process of building a roaster, and im tossing up between either a 2000W electric hot plate, or a Heatgun.
    Any Input would be great.
    The roaster is built out of an old pot with a stirring mechanism powered by a low rpm high torque motor from above.
    Also building a cooler, is pushing or pulling air across the beans better?
    Cheers.
    Dec 2008
    60
    Re: Heatgun Vs Portable Electric Hotplate
    I reckon the heat gun as the heat is more evenly distributed (in my *opinion) through the beans as they agitate...a hotplate would have too much risk for burning and hot spots due to the direct contact with a hot surface.
    As for the cooler blowing will produce a higher rate of flow through the beans I think
    Apr 2008
    Brisbane
    5,115
    If you are going down that path with a pot and external motor see my roaster build
    Well worth a read
    http://coffeesnobs.com.au/YaBB.pl?num=1228631426
    Or see the Power Point Presentation
    http://docs.google.com/EmbedSlideshow?docid=dc5qt26s_0c97xkwgg&size=l
    Edit
    You can also view CS members Hooked & Gra with there successful builds of this roaster (Roasters section)
    I am sure they are getting excellent roasting results
    Mar 2009
    43
    thinking i might save the effort and use my old bread-maker with a heat gun
    Thanks though guys!
    10,496
    Behmor Coffee Roaster
    I prefer to suck air through the beans from below.
    No risk then of blowing them away.
  1. Best Portable Grinder
    By eaglemick in forum Grinders
    Last Post: 26th April 2013, 12:11 PM
  2. portable camping roaster
    By galah in forum Roasters
    Last Post: 23rd April 2013, 10:13 AM
  3. Portable AC Unit??????
    By thegoodies in forum Off Topic
    Last Post: 25th March 2008, 09:27 PM
