Results 1 to 9 of 9
Thread: Tips for corretto roasting PNG Wahgi AA
    Senior Member Pavoniboy's Avatar
    Jan 2009
    Minnamurra NSW
    693
    Anyone willing to share some tips or even a roast profile for roasting Wahgi?
    I use a corretto and typically roast 500g of green. I usually go for a S type curve on my roast profile, that is starting slow and ever increasing the gradient as I go and then backing off into first crack and stretching 5-6 mins to first signs of second crack.
    I have only done one roast of Wahgi so far and pulled it quite a long way shy of second crack (I was paranoid of hitting second crack as I had read everywhere on here to pull before this)...probably pulled too shy of second crack. It had a lot of green, grassy flavour and no hints of chocolate or the like that I read others get.
    Any advice on how to make the most of the rest of my bag would be highly appreciated.
    Oct 2008
    505
    Re: Tips for corretto roasting PNG Wahgi AA
    Gday Pavoniboy,
    Head over to the cupping room,
    http://coffeesnobs.com.au/YaBB.pl?num=1237180436
    A few roasting tips in that post.
    I have tried both a s roast and a straight ramp to FC and found little difference in the cup.
    Did find a small difference when taken just past SC and just before SC. Just before SC the the cup was a little lighter. Just after SC the cup was a little darker but the same basic taste was present.
    One other thing I noticed was how little heat energy was required between FC and SC. Also hit SC a couple degrees less then other beans.
    Hope this helps.
    Jan 2009
    Minnamurra NSW
    693
    Thanks bassway. Exactly what I was after. Will do my next wahgi roast this evening.
    Nov 2006
    1,077
    I generally go for high heat to start with a ease off as it approaches FC and then let it glide through to the first snaps of SC.
    A great tasting coffee this one.
    I used to follow S type curves an a number of coffees but of late i am putting more heat earlier to get the temp up to 140 - 150deg before easing off as it then stretches out to FC at about 185deg and 10 - 11 mins and then SC at about 205deg and 15 - 16mins.
    I have found by changing the profile that my roasts are far more even than before.
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    Hi Pavoniboy,
    I went a bit further than usual with the last roast and did not like the result. Hit rolling SC and the beans oiled up a little within days. Just not into it in a Short Black at all, but my mate was loving the difference with the darker roast. Each to there own, try a few different levels and see what you prefer. ;)
    Jul 2007
    Werribee, Victoria, Australia
    737
    Hi Pavoniboy,
    I tend to roast 1cr about 192deg 10-12 mins then try to finish before 2cr at about 215 deg.
    I have done about 7 roasts in my corretto with 2 different lots of Wahgi
    a few in my old pot roaster and 1 in my Shrek popper and found it roast very well in all roasters the pot roaster needs a lot more heat.
    With my early roast in the corretto 2cr was constantly around 220deg.
    Your temp reading may differ to other peoples so its best to know your equipment and take notes as to where 1cr and 2cr are in relation to your monitor and roaster.
    Marty
    Jan 2008
    476
    Quote Originally Posted by 75787B75170 link=1239762496/3#3 date=1239783436
    ditto....get to 150deg by 5min. FC by 10. and pull just shy of second or on second ~215deg in my corretto (about 15-16min).
    sd
    May 2007
    Perth, Western Australia
    3,171
    Hi Pavoniboy, my PNG roasts are similar to most above, I take it out with good heat for 5 minutes then ease back gradually and reach first crack at between 11-12minutes, I then cut back the heat to 3C per minute to just before second crack begins around 16-17mins.
    First crack on the GMC is usually around 195-200C and second 215-220C depending on bean and ambient temp in my garage.
    I initially took PNG beans just into second but on advice from fellow roasters started pulling before 2nd crack and noticed an improvement in flavour quality.
    Jan 2009
    Minnamurra NSW
    693
    Behmor Coffee Roaster
    Have cracked open my Wahgi from this second roast and it is much better. I am seeing why so many of you love it.
    Roasted to only 1 degree shy of where I predict second crack would be on my setup.
    Would agree with Bassways previous description of chocolatey port and very long lingering taste. Very nice.
    Thanks for the help :)
  1. Tips for roasting the Aceh Bitang coffee in Corretto setup?
    By roburu in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 2nd April 2012, 05:56 PM
  2. tips for roasting
    By superscooby009 in forum General Coffee Related...
    Last Post: 29th February 2012, 09:08 AM
  3. Corretto roast tips/guide for those getting started
    By rival81 in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 19th December 2010, 06:05 PM
  4. Brazilian Santos Moiana, corretto roasting tips please
    By hotshod in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 14th August 2009, 08:17 AM
