Results 1 to 5 of 5
Thread: 1st or 2nd crack
    Aug 2007
    6
    1st or 2nd crack
    Hey all. I started with the popcorn popper and have moved onto breadmaker + heat gun. Been experimenting with 1st crack vs 2nd crack. Someone said that you should stop before 2nd crack but I have found that is seems to loight. Any suggestions on timing?
    10,496
    Re: 1st or 2nd crack
    Theres a difference between stopping before SC and stopping after FC.
    How do you know how close you were to SC?
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    948
    I have always had difficulty hearing second crack (I am a little deaf if the wife can be believed). So I mainly roast to colour and texture. One indicator to second crack being close or happening is an increase in smoke coming from the beans. However this is not always accurate as some beans do not give off as much smoke as others.
    Use the CS card (or any other colour guide that can be found on the internet) to check the stage your beans are at. If you like your roasts at CS9 then stop your roast when it gets to that colour.
    Aug 2007
    6
    I can usually hear the 2nd crack but there is almost alwaya a lot of smoke at that point, so maybe should be stopping earlier. Thanks for the adivce, will try it out and check out the cs colour chart/
    Dec 2007
    948
    Behmor Coffee Roaster
    When I hear first crack I watch the clour of the beans closley. I rarely if ever go on to second crack, but have once or twice - I like the darker roast but the wife (bless her) prefers the lighter roast, so rarely do I venture into anything over CS 9.
  1. 1st crack - 2nd crack timings?
    By tonee in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 12th July 2010, 05:09 PM
  2. Help!! Cant get up to the 1st crack!!
    By 6tri6ple6 in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 5th June 2010, 12:44 AM
  3. Is it really second crack ?
    By kevviek in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 2nd March 2010, 01:05 AM
  4. third crack?
    By Bidtfaun in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st April 2009, 07:31 PM
  5. First crack & Second crack temps
    By NewToEspresso in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st December 2007, 07:01 PM
