Results 1 to 3 of 3
Thread: Tapachula El Tacana
    Jan 2008
    482
    Tapachula El Tacana
    Anyone roasted this one yet? Did a 500g batch today and as per Andys description, I took it a little darker than normal (a minute into SC on a slow gradient). Pulled as rolling SC was audible and smoke visible.
    The roast looks pretty good, but even into SC its still only around CS 9. Not as dark as i was expecting. Will post some cupping notes in a couple of days.
    FC 10:00 -12:00 188-198deg
    SC 17:00 211deg
    Pulled 18:00 214deg.
    sd
    May 2007
    728
    Re: Tapachula El Tacana
    Ahhh.. found this roasting thread for the Mexican. Say, do you normally get FC at 190C and SC at 211 for your other beans?
    I normally get FC between 198 to 207C for most of my other beans but the Mexican I got FC at 190C and Im wondering if my DMM Temp probe is off... Why Im suspecting my probe is because my original probe died and I got a replacement probe from jaycar but the connectors werent the same so I had to re-wire the probe onto the right connectors.
    The other part of the equation is I have a preference for African beans (and Yemen) so the african are disproportionately high in my green stash which means 4 out of 5 roasts Ill do is african (or Yemen).
    Jan 2008
    482
    Behmor Coffee Roaster
    Yep...since I changed breadmakers my readings have been consistently 5-10deg lower (FC around 190). Im guessing the shape of the bucket and my probe position are the main causes, so I think your probe is probably the issue as you say.
    sd
  1. Mexico Tapachula El Tacana
    By cksyd in forum General Coffee Related...
    Last Post: 6th November 2009, 09:25 AM
  2. Interesting Tapachula El Tacana
    By madpierre06 in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 11th August 2009, 02:58 PM
  3. WARNING!! - Mexican Tapachula El Tacana
    By cksyd in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 6th June 2009, 05:00 PM
  4. Tapachula El Tacana
    By smokeydeck in forum Cup Tasting Room
    Last Post: 2nd June 2009, 09:39 AM
