Results 1 to 4 of 4
Thread: Gene Cafe - profiles based on time after start of FC
    Mar 2008
    120
    I am a novice roaster and I use Gene Cafe. Trying to get an absolutely repeatable result for the beans from the same batch I realized that with Gene Cafe its hard to replicate roasting process exactly for the same bean if I just look at temperature/time recorded during the first roast (because of different ambient temperture, for example, etc)
    However. I think what worked for me was measure time after start of FC. For example for Bani Ismaily I started cooling at FC + 5.first crack, etc.
    Any ideas why I shoulnt be excessively relying on time after FC start? Given the temperature setting is the same and I accurately note the start of FC. Also given I keep the batch size the same? Do you think this method is very reliable?
    Jul 2007
    2,288
    Re: Gene Cafe - profiles based on time after start of FC
    Give it a try and see. If it works for you, it works.
    Me, I go by a combination of time from first snaps of second crack, colour, and what depth of roast I want this time.
    "Consistency is for small minds."
    Mar 2008
    120
    Quote Originally Posted by 74415654645C415E525F57330 link=1244609872/1#1 date=1244809116
    very often I stop before the SC, so I need to have other reference. In some beans SC is so subtle that it would be easy to miss the start of it. Plus the cooling is slow...
    Nov 2008
    62
    Behmor Coffee Roaster
    Quote Originally Posted by 6D666F7C7A7C6B7D0E0 link=1244609872/0#0 date=1244609872
    I always seem to roast to get a certain colour, although will look to SC + puff of smoke if there.
    I always preheat to get some form or repeatability then look to FC to determine if its going faster or slower. Seems to vary upto a minute either way. From there, I have a target to SC, but always check for SC. The time FC - SC does seem to change so you need to keep watching, so I dont think you can just base on time.
    Its the variability that makes the coffee interesting anyway!
  1. Corretto roasting weight and time profiles
    By brokenvase in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 9th January 2013, 09:30 PM
  2. Gene Cafe on its way, but where do I start?
    By MaryP in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 31st May 2007, 02:57 PM
  3. Gene Cafe profiles-- kind of
    By cloudsipper in forum Roasters
    Last Post: 8th March 2007, 06:00 PM
  4. [m]: Gene Cafe profiles-- kind of
    By Dimal in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 4th March 2007, 01:22 AM
