Results 1 to 8 of 8
Thread: Another world opens up
    Nov 2005
    333
    Well, after picking up a $15 heat gun the other day, I finally got around to doing my first couple of heat gun roasts. A nice windy day for it, which helped in winnowing the chaff away from the beans as they dropped through the air from colander to colander while cooling.
    Got to say Im impressed by the heating ability of the gun - its the XU1 with two heat settings. First crack only took about 7 minutes on the low setting with the nozzle 10-15 cm away from my small load of beans (around 180g). Im using a steamer saucepan set into a larger saucepan. Actually I was looking forward to a slightly longer roast time because Ive read that longer roast times bring out the best in beans.
    Its great being able to see, hear and smell all the action. Its a change from the popper and the Imex. Nice and quiet too.
    I stopped both roasts (Peru Kontiki & Yemen Mocha) not long after 1st crack, as I think the last few roasts I did in the Imex went too long for my liking (or perhaps didnt cool down quickly enough). Still learning and experimenting. Next time Ill hold the heat gun a bit further away from the beans but first have to get myself a longer spoon. The taste - even already today - is pretty good!
    I like it :)
    Merry Christmas everybody.
    Rob
    JR
    JR is offline
    Dec 2004
    110
    Re: Another world opens up
    Rob
    You should also consider increasing the batch size with your XU1. My standard roast volume is 300g but can easily double to 600g while still feeling in control of the roast. I find any less than 300g and the roast progresses too quickly and I am constantly trying to finesse the roast to perform as I desire. 300g is a good balance which allows me to easily roast quickly or slowly depending on what I am trying to achieve.
    What are other HG roasters using per batch?
    Dan
    Jan 2005
    338
    Id agree with Dan, when I used the dogbowl I tried 350 and it worked well, and gave a very even roast.
    I"m still using the heatgun, but its mounted now. Im using 500g at a time and the roast takes about 20mins to get to 2nd crack.
    Mar 2004
    200
    Quote Originally Posted by Dan link=1135415418/0#1 date=1135420495
    Rob
    You should also consider increasing the batch size with your XU1. *My standard roast volume is 300g but can easily double to 600g while still feeling in control of the roast. *I find any less than 300g and the roast progresses too quickly and I am constantly trying to finesse the roast to perform as I desire. *300g is a good balance which allows me to easily roast quickly or slowly depending on what I am trying to achieve.
    Dan
    My av roast size is 800g, gotta use *a big bowl/colander to allow vigorous stirring. SS Pasta pot with modular strainer works well for me.
    Around 16 minutes to second crack, if I stir enough the beans are very even, if I get lazy I just say the variation is deliberate to add complexity ;)
    Jul 2005
    131
    My average is 300gm. I have been using the higher heat setting on the gun so as to get to !st X as quickly as possible, usually about 5-6 min. then I use the lower setting to maintain the heat and if 2nd X has not happened by 13 min I go back to high heat to finish off, aiming for about a 15min roast.
    Bruce
    Nov 2005
    333
    Thanks people - Good advice there. Ive increased to 300g batches and all is well. The roast time has extended a bit. I imagine 400g or thereabouts would give me perfect 18 minute roasts, but thats a bit too much coffee for me per roast. I guess I could always hold the HG a bit further away but then I wouldnt be able to rest it on the edge of the pot.
    Is the general consensus to ramp up the heat at the end? Every roast profile Ive seen seems to suggest this.
    Rob
    Jan 2005
    338
    Mostly I think the roasting curves level off? So you get to first crack on the higher heats, then you let it coast into 2nd (if you want to take it that far, I mostly prefer a city - full city personally)
    Ive got to remember to ramp the gun down to the low heat setting on first crack sometime, see how that works out. Also Ive gotta get a propper thermometer to do some roast curves.
    Currently Im musing over a sample roaster like Sharkboy.
    Aug 2005
    1,530
    Behmor Coffee Roaster
    Roasting curves often plateau well before 1st crack. The bit before 1st crack is where you really want to ramp it up, then extending the roast through 1st and into 2nd crack. Youre better off keeping the heat fairly constant, if not slightly lower to increase the complexity in the roast.
  1. Is the world becoming a DFO?
    By claraflo in forum Off Topic
    Last Post: 23rd March 2012, 09:57 PM
  2. World Blend 15
    By Dennis in forum Blending Room
    Last Post: 21st February 2008, 11:41 PM
  3. Fine Foods Qld opens 26-28 March
    By gilkatho in forum General Coffee Related...
    Last Post: 25th March 2006, 08:07 PM
