Results 1 to 4 of 4
Thread: Upper and lower heating temperatures
    Jun 2009
    20
    Hi All,
    Im currently calibrating a drum roaster setup, and have successfully built a very effective bean incinerator. Im now working on building in some automated valves to inject cool air and vent hot air, but now Im left wondering exactly what temperatures I should be aiming for. Naturally temps will vary from bean to bean, but I was hoping someone might have an indication of whats a good range of temperatures to shoot for.
    Currently I have a burner that on the lowest setting before it starts sputtering stabilises at 250 degrees, and on high it got up to temperatures that had extremely alarming noises coming from the enclosure.
    Im thinking Im probably going to want to have a system that I can use to hold a stable temperature from 160 to 230 degrees but am very interested to hear common wisdom on the matter before I start building manifolds so I can try to get the best resolution of control over the relevant range.
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    948
    Re: Upper and lower heating temperatures
    I use a coretto and my roasts usually finish at about 215 deg and 217 deg. FC at about 195. Hope that helps but I think there will be variations.
    May 2007
    Perth, Western Australia
    3,174
    Corretto--198-200C first crack, 216-200C second crack for mine!
    Nov 2007
    BRISBANE
    202
    Behmor Coffee Roaster
    My Corretto temps are virtually the same as greenman.
    I think he means 216-220C second crack.
  1. Upper/Lower North Shore, Sydney
    By yeeza in forum NSW-ACT
    Last Post: 18th May 2017, 08:20 PM
  2. Corretto & Colder Temperatures
    By bolb in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 17th April 2008, 05:54 PM
  3. Espresso temperatures
    By pszilard in forum General Coffee Related...
    Last Post: 28th December 2006, 03:59 PM
