Results 1 to 29 of 29
Thread: First popper roast a success thanks to the info on this forum.
    Jun 2009
    80
    Hi All,
    Just completed my first attempt at roasting beans with a popper and thanks to all the fantastic information contained here, it worked. *
    Hard to believe that a month ago I was using a $99 Sunbeam coffee machine and now thanks to this forum I have a Giotto Premium Plus, A Kompac grinder and now am roasting my own coffee :-)
    A quick trip to the K-Mart got me a Tempo Popper for $25. I raided the kitchen and found most of the other stuff I needed. *I ordered some beans from BeanBay - the choice (Sumatra Sipangan Bolon)was a little random but I figured you gotta start somewhere and Ill learn how to make an informed choice over time.
    After much reading about the science and art of coffee roasting I decided to (mostly) ignore the science and go for the art. *All the modifications and temperature probes, etc just seemed a little too much for someone starting out.
    I added the same amount of beans as the popper suggested for popcorn, fired up the popper and waited for first crack.
    I had decided in advance to remove the beans just past second crack (or at charcoal if I couldnt tell what the second crack was) so I let the second crack get well underway before switching off and cooling the beans.
    The end result was 50g of very evenly roasted beans that Ill be interested to try in another day or so. *i did two more batches that were slightly less even but I think thats because I tried roasting more beans than the first batch.
    Anyway, thanks everyone for the incredibly useful information contained here. I couldnt have done it without you!
    And for anyone reading this who wants to give roasting a try - my advice is dont stress over the technical details, just go with the basic concepts and give it a go...
    Jul 2007
    2,288
    Re: First popper roast a success thanks to the info on this forum.
    Look mate, dont spread it around. >:(
    Letting others know how easy home roasting is, just sets up Green Bay for a rush.
    Keep it to yourself, or all the great beans go in a minute or two. :(
    Oh, and welcome to the addicts corner. ;)
    Oct 2008
    488
    Quote Originally Posted by 6B6467676A010 link=1248146635/0#0 date=1248146635
    Great approach, and
    Great advice!
    Jun 2009
    80
    Now I figure Ill taste the beans every day to see how they change over time.
    After 24 hrs the taste is leaning a little toward the sour side but not undrinkable. So far so good, I think.
    The plan is to add some more bean varieties over the next few weeks, spend a month or two with the popper and then tackle the whole Corretto building thing.
    ...or if the tax man is nice to me, something like a Gene Cafe, although Im not sure if its worth it for someone like me who only uses a small amount (150g or so ) of coffee each week.
    Oct 2008
    488
    The Gene is probably more suited to your needs because (depending on BM size) the coretto often needs 400g+ batch sizes to achieve an even roast, while the Gene will quite easily do 200g batches.
    That said, I love my coretto!
    Jul 2007
    2,288
    Quote Originally Posted by 2C242B2D257F7A4E0 link=1248146635/4#4 date=1248222381
    And as the only coffee drinker in the house, and a moderate one at that, the Gene Café has a place of honour here.
    Jun 2009
    80
    Quote Originally Posted by 4B434C4A42181D290 link=1248146635/4#4 date=1248222381
    Hmm... Hadnt thought or read much about minimum batch sizes :-?
    I can see another conversation that goes along the lines of
    me: "I was just reading the Coffee Snobs forum..."
    wife: "How much this time?"
    :D
    Jeff K
    Jan 2009
    264
    Assemble a corretto.....
    Cheap to build and fun to use , plus this forum will help you no end, and your friends will be blown out by your new hobby.
    Remember , even at 400g roasts you still end up with 320g brown bean , so thats just a weeks worth .. ;)
    Go for it...!!!!
    Jun 2009
    80
    Thanks Greg,
    For me, being the only coffee drinker in the house, 320g is about two weeks worth of coffee but thats ok. If I make more than I can use Ill just have to invite more friends around help me drink it :-)
    Is 0.8 a fairly standard ratio for roasted vs green weight? I guess it depends on the beans a bit?
    I have the heat gun and an old tripod I plan to mount it on, so all I need now is the old bread maker. Im still trying to avoid making things too high tech with temperature probes, etc. (which is weird for me casue Im a technology junkie...)
    Ill give the popper another month or two while I build up a bigger supply of beans and learn from the inevitable disasters, then give a corretto a try.
    Jeff K
    Jan 2008
    1,756
    Beans will last for two weeks without too many dramas, best usually around day 5-10ish, but definately drinkable from 10-14 generally and remember you can do smaller roasts in a most correttos, i can do as little as 150g with my setup, which doesnt seem to work too well with some BMs but it does with mine, so that will produce around 125g of roasted beans, and 0.8 isnt a bad guestimate for green to roast ratio, but yes it does change with bean type, some of the real roasters here will be able to tell you why this happens ::)
    Jan 2009
    264
    Hi Jeff ,
    There are CSers here that have been doing this for years , me , 3 -4 weeks , and I cant tell you how much fun it is to do, sure you have your duds , but refining the technique is all part of the journey.Plus this forum embraces the newbie....
    If I look back to what the household consumption was prior to E61 and corretto arriving , its doubled easily within the family and friends.... friends look to see if the machine is on !!!!
    My wife used to drink 2 cups of flat white per week ( weekends only ) out of our old Saeco.... No more she is now at least 8 Decafs and 4 Full Caff Cappuccinos per week, shes not addicted just loves it...... Beware !!
    I think green to brown losses are 16-20% for most roasters.
    From my limitted experience you need a digital thermometer with thermo probe , its not high tech , you dont have to log on a laptop , pen and paper work fine , but you need to know whats happening in the BM basket.
    Smaller roasts are possible, but at 400g and above there is far more consistency and control.....
    all the best
    Jun 2009
    80
    Quote Originally Posted by 1612342D2D2837202F410 link=1248146635/9#9 date=1248306086
    I have in mind that I would probably roast about 200g at a time - so I guess I should be looking for the smallest volume BM I can find?
    Oct 2008
    488
    Quote Originally Posted by 444B4848452E0 link=1248146635/11#11 date=1248313443
    I have in mind that I would probably roast about 200g at a time - so I guess I should be looking for the smallest volume BM I can find? *
    Yer usually the smallest is around the 750g mark. As a guide, people suggest that you should be utilising about 60% of the bucket. But as WSully said, you can do quite small batch sizes. You are probably just compromising a little on control of the roast and the evenness of the roast
    10,496
    My BM would be about 750g and I started off doing 300g greenweight roasts.
    They were good but eventually I moved up to 600g roasts and found that I got used to those and the occasional 300g roast was a little harder to do.
    I know the limit of my bm is 700g because I tried 720g once and stated to lose a few over the top and it was also a little difficult to control after being used to 600g batches.
    I think 200g would be too small a batch..
    300g nets about 250g roasted weight.
    Thats the same as a store bought bag; most people are used to buying that much at a time.
    Feb 2009
    North Rothbury, NSW
    1,104
    Quote Originally Posted by 516D706B616077626A61050 link=1248146635/13#13 date=1248316910
    Agreed
    I have moved from minimum 250g batches to 300g batches. It makes a noticeable improvement in control for only a small increase.
    Jun 2009
    80
    OK, so 300g isnt unreasonable in a Corretto then?
    I think I have to up my coffee consumption estimates anyway... the 140g I roasted on Sunday and started taste testing on Monday is all but gone by Thursday. :o I think Im still getting used to the volume of coffee I seem to be using now I have a decent machine.
    Feb 2009
    North Rothbury, NSW
    1,104
    Quote Originally Posted by 505F5C5C513A0 link=1248146635/15#15 date=1248325679
    OK, so 300g isnt unreasonable in a Corretto then? *
    Not at all. As you have said, you have half the kit already, like I did. Your outlay is small to have a lash. All you need is a breadmaker....
    BUT.....then you gotta cool them down... :-/
    Off to Bunnings Jeff, big bucket, 20cm exhaust fan and some fiddling...
    Jun 2009
    80
    Quote Originally Posted by 7F776F65781C0 link=1248146635/16#16 date=1248326099
    The cooler could be my next pre-corretto project I think. I assume the exhaust fan is set to suck air through the beans?
    Feb 2009
    North Rothbury, NSW
    1,104
    Yup
    And I got a drum sieve from a catering shop that sits in the top of the bucket above the fan.
    It will cool 500g of beans in less than 2 minutes
    Ill take a pick of the completed thing on the weekend and post it if you like
    Jun 2009
    80
    Thanks, Id love to see it.
    Feb 2009
    North Rothbury, NSW
    1,104
    Quote Originally Posted by 6D6261616C070 link=1248146635/19#19 date=1248343795
    No prob, Ill do it Saturday.
    The drum sieve also doubles up to make brilliant pommes puree (mashed potatoes) :D
    Jul 2007
    2,288
    Quote Originally Posted by 2D253D372A4E0 link=1248146635/20#20 date=1248345187
    The drum sieve also doubles up to make brilliant pommes puree (mashed potatoes) *
    According to my French, pommes purée is applesauce. "Pomme de terre" is potato. ;)
  23. #23
    Feb 2009
    North Rothbury, NSW
    1,104
    Quote Originally Posted by 1C293E3C0C3429363A373F5B0 link=1248146635/21#21 date=1248417243
    According to my French, pommes purée is applesauce. "Pomme de terre" is potato. *;)
    Well there ya go - and google language tools agrees. *:o
    Makes those chefs on Masterchef look a bit silly then. That is where we got it from. *:-?
    So i guess we use it for pomme de terre puree then ;)
  24. #24
    Feb 2009
    North Rothbury, NSW
    1,104
    So the French think the potato is the apple of the earth? ;D
  25. #25
    May 2008
    4,266
    Not just the French. The Dutch call it "aardappel" which has the same literal meaning.
    But you wouldnt be putting one in your popper (to steer this thread back on topic) :)
  26. #26
    10,496
    Quote Originally Posted by 747C646E73170 link=1248146635/22#22 date=1248417862
    I stopped watching after the episode where the resident chef reminded the contestants to remove the spine from the calamari. :o
  27. #27
    Feb 2009
    North Rothbury, NSW
    1,104
    Hey Jeff
    Here is the cooler.
    I think the shots are pretty self explanatory. A bit of overkill done mounting the fan - I have a mate who loves to over-engineer things ;D - really all that is needed is three L shaped bracket rivetted to the buckt at the appropriate screw hole points in the fan and you are away.
    The fan already comes wired with a standard 2 point plug so its really simple.
  28. #28
    Jun 2009
    80
    Thanks! Looks like Im off to Bunnings in the morning :-) if I can get the breadmaker I was given this morning to run a dough cycle for more than 15 mins Ill even have a Corretto to try it with...
    jeff K
  29. #29
    Feb 2009
    North Rothbury, NSW
    1,104
    Behmor Coffee Roaster
    Quote Originally Posted by 4F4043434E250 link=1248146635/27#27 date=1248507234
    Thanks! *Looks like Im off to Bunnings in the morning :-) *if I can get the breadmaker I was given this morning to run a dough cycle for more than 15 mins Ill even have a Corretto to try it with...
    jeff K
    Cool mate [smiley=thumbsup.gif]
    I have replied to your BM issues in your other thread
  1. First popper roast
    By C-man in forum Roasters
    Last Post: 8th July 2012, 04:11 PM
  2. First Roast: Peru Popper Roast
    By iggs in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 1st July 2011, 05:17 PM
  3. first roast success!
    By tridge in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 16th August 2009, 03:35 PM
  4. First roast success
    By SamR in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 24th March 2008, 08:29 PM
