Results 1 to 10 of 10
Thread: Roasting not just browning
    Mar 2009
    Redlands,Queensland
    652
    guys have not long been roasting via popper as heat gun blew up and had a popper in cupboad so thought I might give it a shot.
    My question is around roasting my coffee rather than just browning it. Wth the heat gun u could turn down the heat to give it time to roast bringing out sweeter dlavours etc. But with popper either on or off. How can I slowly roast my coffee?? Thought cover chimney with all floil and switch off popper and switch on-repeat???
    10,496
    Re: Roasting not just browning
    Which popper do you have?
    (Your foil and on off suggestion wont work)
    May 2008
    4,261
    You could try directing a fan across the top of the popper after FC which may suck out some of the heat (venturi effect) to slightly extend the time into SC.
    ...or you could buy another HG *:-/
    Mar 2009
    Redlands,Queensland
    652
    TG I think it is a black n decker.
    What I meant with the foil is when I switch off the popper put foil over the chimney for 30 seconds or so then switch on popper again and uncover, keep doing until FC then SC.
    Thoughts its kinda like a mini oven. :-?
    Feb 2009
    275
    Hi mC,
    Apparently with poppers it is widely recommended NOT to cycle them without thorough cooling between uses.
    In the poppers that I have opened including the B+D, the circuit board and motor are close to the heat source. I concluded that repeated uses may allow heat to infiltrate to the motor and cook it when its running (probably what TG was getting at).
    To cool the popper contents you could increase the air flow (may be difficut) or spray a little fine spray of water on beans (maybe using a $2 spray bottle) I have not tried this but apparently commercial roasters have or may resorted to this method.
    Like FA to fix or replace heat gun would be my preferred approach.
    Lindsay
    10,496
    Do a roast and tell us the times you achieve 1st and 2nd crack.
    From there you can decide how much modification you need.
    17,558
    Quote Originally Posted by 707572786F7D656E7D1C0 link=1248353839/4#4 date=1248387789
    Spot-on Lindsay... 8-)
    Eventually the (plastic) fan either softens around the hub and rips the centre out or the blades harden and become brittle enough to shatter. Either scenario spells doom for the popper though.... :(
    TG has some great tips on how to get the best out of a popper and his contributions in this thread (and many others)... http://coffeesnobs.com.au/YaBB.pl?num=1174699442 is worth your taking the time to read.... ;)
    All the best :)
    Mar 2009
    Redlands,Queensland
    652
    TG roaster almost 700g this week on the popper FC is around 3:25 and SC around 4:50 been roasting El Salvador green beans.
    time wise how does that sound. My first roast was FC 3:40 and SC 5:55 but was dark and tasted a little burnt.
    Roasts now dont taste too bad, but know the slower the roast the sweeter the taste. So wondered if you could slow down the popper/switch off and on. But also did think about burning out the motor- hence asking about it.
    10,496
    Quote Originally Posted by 46464648444D4D4E4E2B0 link=1248353839/7#7 date=1248438723
    Typical popper.
    I have a Crazy Popper.
    I added extra holes underneath to let in more cool air and took the top half of the body off to let out more heat.
    See if you can do similar to yours.
    Get more cool air in and drill some holes in the body to let the trapped heat out.
    Mar 2009
    Redlands,Queensland
    652
    Behmor Coffee Roaster
    thanks everyone will try a few more things and see how we go. Its coming along well now Im just as we r all a little/ or a LOT snibby about my coffee ;D
  1. Pros & Cons - Air Roasting versus Drum Roasting
    By Dolcimelo in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 9th January 2013, 10:37 PM
  2. home roasting into commercial roasting
    By drink1121 in forum Roasters
    Last Post: 28th September 2012, 11:36 PM
  3. Cast Iron Pot roasting…gas fire roasting
    By colombiasmoothbean in forum Roasters
    Last Post: 17th May 2012, 05:17 PM
  4. New to Roasting
    By scollops in forum Roasters
    Last Post: 11th May 2010, 06:10 PM
