Results 1 to 4 of 4
Thread: Installing a switch to my corretto?
    Jul 2009
    12
    Just wondering if anyone has any idea how to install a switch into a corretto? I have a breville bb200 breadmaker. Will I need an electrician to do this or is it possible to do it myself?
    Feb 2009
    North Rothbury, NSW
    1,104
    Re: Installing a switch to my corretto?
    Hi there CM
    Yes it is possible, as a mate of mine did it recently to that same model for another CSr.
    Pretty much he hardwired the motor to the switch he installed and threw most everything else out.
    BUT.....
    If you are not extremely comfortable with electrical workings (as I am not) then try and find an electrician to guide you or do it for you. Hope you can find one through friend of a friend or something.
    Good luck, but please dont go playing with electrickery if you are unsure.
    Jul 2009
    12
    Thanks cksyd, I have an uncle who is an electrician, but he works on oil rigs so he is usually offshore.
    Hardwiring the motor sounds like the thing to do, Ill have a look into it but I dont think Ill be going near the electrickery.
    Cheers!
    Feb 2009
    North Rothbury, NSW
    1,104
    Behmor Coffee Roaster
    At least you know it can be done mate.
    It goes when YOU tell it to and stops when YOU tell it to. Sounds like a perfect corretto machine!!
    Good luck
  1. Installing PID on QUAHA
    By dogban in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 25th December 2011, 10:54 AM
  2. Installing thermocouple in corretto
    By bmcquillen in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 23rd July 2011, 03:26 PM
  3. installing a PID
    By ajhclarke in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th February 2009, 10:45 AM
