Results 1 to 25 of 25
Thread: Things that go BOOOOOM!
    May 2007
    728
    I suspect this is not the first to happen to a CSer, nor will it be the last...
    I roast my beans in a corretto in mainly 2 different ways; my heatgun is a Aldi Taurus special with 2 fan and heat settings, the low setting has a slower fan and doesnt go up too high in temp(Im guessing 250C), the high setting is a higer fan speed and up to 550C. When I want a slower heat ramp up form the beginning I use the low setting and a wooden "cover" with a hole in it to insert the HG nozzle. When I use the high setting, no cover is used and the HG sits really high up above the beans.
    Measured out a 250g batch of the Ethiopia Sidamo Guji and this one I found to benefit from a slow ramp up so, the cover goes on, and I ws rushing to set it up because I had to go to the crapper... Switched it on, went to the little boys room and approx minutes later when I came out, there was thick yellow smoke in my whole garage and the poitn of origin was the corretto... Fought my way thru the smoke and first thought it was a severe HG failure but realised I had the heat setting on high and cover on and HG quite deep in... Still connected to the laptop, I had a look at the roast (more like BURN) profile, FC at probably 1 minute, got to 550C and stayed there for a while....
    May 2007
    728
    Re: Things that go BOOOOOM!
    My roasting is now on hold for a while until I get myself another breadmaker, heatgun etc, or at least limited to small batches done on the IMEX.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 49627053684274777562747468070 link=1258260946/0#0 date=1258260946
    Measured out a 250g batch of the Ethiopia Sidamo Guji and this one I found to benefit from a slow ramp up so, the cover goes on, and I ws rushing to set it up because I had to go to the crapper... Switched it on, went to the little boys room and approx *minutes later when I came out, there was thick yellow smoke in my whole garage and the poitn of origin was the corretto... Fought my way thru the smoke and first thought it was a severe HG failure but realised I had the heat setting on high and cover on and HG quite deep in... Still connected to the laptop, I had a look at the roast (more like BURN) profile, FC at probably 1 minute, got to 550C and stayed there for a while....
    I think it is in ever handbook and even for major systems..
    NEVER EVER LEAVE the system Unattended...
    May 2007
    Perth, Western Australia
    3,172
    Confucious say "always go to crapper before roasting beans"--good work there newto :( :( :( :( :( :( :( :( :(
    May 2007
    728
    Despite the loss of the BM, HG, beans etc, I consider myself pretty fortunate because:
    i. The petrol tank near the setup was untouched
    ii. My laptop and DMM are untouched
    iii. The neighbours werent around otherwise they might have called the fireys... would have been half funny to come out of the crapper and find a fire truck hosing down the corretto...
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 4B6072516A407675776076766A050 link=1258260946/4#4 date=1258262000
    Yea... The Investigations may have reviled a lack of Smoke detectors and what some might consider an interesting practice?
    Opps... In some places it could have also meant; fines for having them pay a visit
    Nov 2006
    1,077
    Next time can you also keep fireworks close just for the added exitement ;D
    10,496
    Quote Originally Posted by 1F3426053E142221233422223E510 link=1258260946/0#0 date=1258260946
    What you meant to say was youre hoping you arent the first one to do this.
    May 2007
    728
    Quote Originally Posted by 4478657E747562777F74100 link=1258260946/7#7 date=1258269174
    Touche...
    10,496
    What do I roast next,
    no, what do I kill next....
    ;D
    Mar 2004
    Internet
    17,508
    Quote Originally Posted by 664D5F7C476D5B585A4D5B5B47280 link=1258260946/4#4 date=1258262000
    Pre-Darwin Award nominee?
    Sheeze NTE, dont leave the roaster (any roaster) alone for a minute and certainly dont roast near a petrol tank!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 4D6268750C0 link=1258260946/10#10 date=1258293844
    Maybe an Honorable Mention:
    http://www.darwinawards.com/slush/submit_story.html
    Would also get the CoffeeSnobs into another media pool ;D
    Sep 2008
    759
    Quote Originally Posted by 78575E5C4B745857585E5C545C574D390 link=1258260946/11#11 date=1258323720
    And give some negative publicity. I dont go by the adage that all publicity is good publicity.
    10,496
    As always, should you or any of your CS force be caught or killed, Andy will disavow any knowledge of your actions. Good luck, NTE. This tape will self-destruct in five seconds.
    May 2007
    728
    Leaving the roasting unattended - unfortunately, I dont think I have the diligence or the good sense to stop this practise in future; Ive done that heaps of times in the past before this mishap, and this time all it took was a moment of brain fade and flicked the switch the wrong way.... I suffer from adult ADHD (not diagnosed) ie. just cant sit still for more than half a minute unless Im asleep. Watching the a roast go I would have done in the early roasting days. Now its just monitoring it every couple of minutes to make sure the roast profile is as expected (or at least close to).
    Petrol tank... didnt make the connection until I took that photo, noticed the red container in the background is the petrol tank for the mower...
    Update - just bought a used bM from the bay of evils, new corretto project to commence soon. A colleague of mine suggested a overheat cutoff switch; dont know how Id incorporate one of that in. Chances are it will be the same setup as before EXCEPT Ill be using a variable temp HG from now on. No more cheap 2 speed HGs for me.
    Sep 2008
    759
    The question on everyones lips is, what did the coffee taste like? ;D
    May 2007
    728
    Roast was very even, appearance was dark, Id say CS15...It had a distinct slightly ashy aftertaste..... ::)
    Senior Member speleomike's Avatar
    Nov 2005
    976
    Hi all
    I have a 2kg fire extinguisher handy in case of a fire in my roaster. Its a dry powder one as I could not seem to find where to buy a CO2 one. Dry powder will make a mess of a roaster but a fire makes a bigger mess.
    Mike
    Senior Member Dennis's Avatar
    Feb 2007
    4,513
    Quote Originally Posted by 66657079707A787C7E70150 link=1258260946/17#17 date=1258377689
    Hi all
    Mike
    I believe a bucket of water is the preferred method. ;)
    Sep 2008
    759
    Quote Originally Posted by 00212A2A2D37440 link=1258260946/18#18 date=1258401708
    I believe a bucket of water is the preferred method. Wink
    Yeah, with electricity around. What was that about Darwin awards again?
    I also have a fire extinguisher - dry powder.
    Feb 2008
    1,339
    Quote Originally Posted by 65676B63636D6A77040 link=1258260946/19#19 date=1258405722
    If I understand correctly, Michael has a Has Garanti and was speaking of a possible fire in the drum, not in the control board. :P
    Jul 2007
    2,288
    5kg CO2.
    Bought from a local extinguisher supply company--located the old way--Yellow Pages.
    My mother used a dry powder one once. It put the fire out fine--and took 5 days to clean the powder out of every cupboard and off every surface in the house. This is necessary as the powder is corrosive!
  23. #23
    May 2007
    728
    My Remington BM was the BM100. I just collected the 2nd hand BM that I won and its a Tiffany BM642. Opened up the cover and I got to say they look exactly alike! Wont be surprised if it was the same factory that made both these (and probably more) brands and just rebadged them differently.
  24. #24
    May 2008
    437
    Laughing my head off! Thanks for the pics.
  25. #25
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    948
    Behmor Coffee Roaster
    Always have a fire extinguisher handy and first aid kit looking at what is around where you roast ;D ;D
    I dont laugh to loud as I dont know what will happen in the future - it may be me confessing my sins to the understanding but sarcastic audience that is Coffeesnobs 8-)
  1. Moving on to other things...
    By TC in forum Off Topic
    Last Post: 24th April 2011, 11:59 AM
  2. All things are Possible
    By TEPIN in forum Art Gallery
    Last Post: 21st February 2007, 02:35 PM
  3. not sure about a few things
    By DrT in forum General Coffee Related...
    Last Post: 10th October 2006, 10:34 PM
