Results 1 to 5 of 5
Thread: Roasting... affects strength?
    Oct 2009
    Geelong
    1,221
    Ive heard two opposing sides (again) regarding the roasting process. Does roasting darker and darker decrease the strength of the bean (as in decrease caffeine content)? Or does it have no effect because caffeine has a very stable structure and wouldnt be affected?
    As far as i understood (and have read, which may or may not be legit), all arabica beans are the same caffeine content (robusta having a higher content), and the Strength indicator youll see on packets of coffee are actually based on the thought that because its roasted darker it isnt as strong, which i thought was incorrect.. (maybe its referring to a stronger taste as opposed to caffeine content..)
    This article here doesnt really clear things up for me either...:
    mod edit- link removed
    Thanks guys!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Roasting... affects strength?
    Quote Originally Posted by 6872767475687023691B0 link=1259200485/0#0 date=1259200485
    Thanks guys!
    Generalisation Vs facts Vs Have we got something to sell you etc..
    Which is better Super or Unleaded ?
    1: Observe and test.. *Show me any Decaf that is not a DARK roast... *Even after water and other treatments
    2: Caffeine is stable... Under what conditions... Me thinks NOT...
    3: Same caffeine content giggled like a schoolgirl - Abstract below... Mean / Average / 95% confidence/ Standard deviation etc etc
    4: If you want facts do some real research and ignore the ravings that are promoted on many so CALLED coffee sites.. (mod removed ). * Look for papers written and published by unis and other places that have a level of respect.. Even Wikipedia has better comments than many so called coffee forums etc
    FOR IE. *Genetics and Molecular Biology - CAFFEINE CONTENT OF ETHIOPIAN COFFEA ARABICA BEANS
    ABSTRACT
    The coffee germplasm bank of the Instituto Agronômico de Campinas has many Coffea arabica accessions from Ethiopia, which is considered the primary center of genetic diversity in coffee plants. An evaluation of the caffeine content of beans from 99 progenies revealed intra- and inter-progeny variability. In 68 progenies from the Kaffa region we found caffeine values in the range 0.46-2.82% (mean 1.18%), and in 22 progenies from Illubabor region these values ranged from 0.42 to 2.90% (mean 1.10%). This variability could be exploited in a breeding program aimed at producing beans with low-caffeine content.
    Oct 2009
    Geelong
    1,221
    Yeah, i certainly do not just believe everything i read for the record, am merely just speaking what i have observed ;). Thank you, i will do some research on actual science-based sites, was just wondering whether anyone had come across whether roasting affects the caffeine content or strength..
    Jul 2007
    2,288
    Does strength relate to caffeine, taste, or intensity of taste?
    I suspect it is used for all three without differentiation or definition.
    Oct 2009
    Geelong
    1,221
    Behmor Coffee Roaster
    Im using the term strength in a strictly caffeine-content sense.
  1. Pros & Cons - Air Roasting versus Drum Roasting
    By Dolcimelo in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 9th January 2013, 11:37 PM
  2. Cast Iron Pot roasting…gas fire roasting
    By colombiasmoothbean in forum Roasters
    Last Post: 17th May 2012, 06:17 PM
  3. How humidity affects grind particle size
    By Sparrow in forum General Coffee Related...
    Last Post: 8th November 2010, 10:32 PM
  4. Settling grounds in portafilter affects taste
    By GregWormald in forum General Coffee Related...
    Last Post: 6th November 2008, 09:17 PM
  5. overdose/underdose and how it affects taste
    By dsc in forum General Coffee Related...
    Last Post: 3rd April 2007, 05:56 AM
