Results 1 to 15 of 15
Thread: Overloaded coretto
    Senior Member Philby1981's Avatar
    Jun 2009
    155
    Overloaded coretto
    Tried roasting 600g Eth Har in my BB280,
    Bitt off more than i could chew i think, temps ramped well early on but struggled getting to FC and again to SC. Schorched a few beans >:( by putting heat gun too close to beans at one stage (only a few). Bit of an uneven roast.
    Once it got to SC I took it a little longer into it as i was after a darker roast ended up between CS10 to CS11.
    hoping i havent wasted them, will see on a few days
    Phill
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,368
    Re: Overloaded coretto
    Quote Originally Posted by 774F4E4B455E161E1F16270 link=1261529795/0#0 date=1261529795
    Bitt off more than i could chew i think, temps ramped well early on but struggled getting to first crack and again to SC. Schorched a few beans *>:( by putting heat gun too close to beans at one stage (only a few). Bit of an uneven roast.
    Phill
    What type of heat gun are you using Phil? I regularly roast 600 grams in mine without any problem using a Bosch variable temp set on approx 450 fan speed 2, positioned about 3 inches above the beans, I have half of the pan covered which I suspect helps with heat retention , even wondered if it would handle a KG.
    Merry Christmas,
    Jon. :)
    Aug 2006
    1,588
    600g is my standard starting mass - it delivers a neat half-kilo roasted. Ive not had problems except that sometimes with quite wet beans they need a little help in the first 3 minutes until they lose a little of the initial moisture.
    Jun 2009
    155
    Using Ryobi heat gun with the variable heat setting, 2000W. I usually roast between 400g and 500g. As I watched it going it didnt seem to be stiring the baens as well as usual. hence the slightly uneven roast. from about 205 deg onward, it was really sluggish rise. got there in the end. Just concerned that the few that got burned wont effect it too much.
    Merry Christmas to you too :)
    Jan 2008
    482
    Gday phill,
    Ive roasted a lot of harrar and find it needs more hands on attention between cracks. I consder it my nemesis but have found great results pulled a couple of degrees before SC. CS 8-9 (with a couple of 10s).
    I also ramp towards an early FC (starting at 9-10 min)to accentuate the blueberries. My preference.
    I also use a variable Bosch and roast 625g batches (4 to a bag).
    Keep at it. Worth the effort.
    Sd
    May 2007
    Perth, Western Australia
    3,174
    Phil, I did 200 plus roasts with a 2 speed Ryobi 600g batches with no problems, nice even roasts no tipping.
    Jon, I experimented with a Breville big loaf twin paddle and 1.2kg batches but it was hard to control the heat and I ended up with beans with a charred taste and tipping, I dropped back to 900g and that worked well with better control and ramping etc, but I still find 600g the best for good heat control.
    Jun 2009
    Moonta SA.
    7,368
    Quote Originally Posted by 445146464D4E424D230 link=1261529795/5#5 date=1261545743
    Jon, I experimented with a Breville big loaf twin paddle and 1.2kg batches but it was hard to control the heat and I ended up with *beans with a charred taste and tipping, I dropped back to 900g and that worked well with better control and ramping etc, but I still find 600g the best for good heat control.
    Thanks Greenman, mines only a single loaf single paddle so you may well have answered my question.
    Do you roast with the top open, covered or partly covered? :)
    17,587
    Quote Originally Posted by 263324242F2C202F410 link=1261529795/5#5 date=1261545743
    Same experience with my Big Loaf and Ryobi 2-Speed gm.... Although, with my original Aldi heatgun, I experienced no problems whatsoever with roasting batches up to 1.2Kg, and could comfortably roast 600g batches using it on its Low setting. Was a bit of a beast that heatgun and I miss its versatility.... :)
    Jun 2009
    Moonta SA.
    7,368
    Quote Originally Posted by 05282C202D410 link=1261529795/7#7 date=1261554599
    Are they still available Mal?
    17,587
    Unfortunately not Jon.... :(
    Aldi do have heatguns advertised occasionally but from a couple of inspections I made of them, they were quite obviously sourced from a different manufacturer so that put me off buying one.
    My old one was supposedly rated for a 2,000W output but it was more likely upwards of 2,400W.... never tripped the breaker on my portable RCD unit but it must have been close.... ;D
    May 2007
    3,174
    Quote Originally Posted by 1C20293124450 link=1261529795/6#6 date=1261553404
    with my single paddle bm the top open with *Ryobi 2-speed
    am experimenting with the twin paddle, Makita variable temp and fan hg *and semi covered at the moment 600g and 900g batches are roasting nicely with good control but any larger and it all goes haywire ::) ::)
    Jan 2009
    264
    Hi Phill,
    I run a BB270 , which is a small ,square shaped basket, with one paddle and this has always limmitted the size of my batches...... every 500g batch has struggled , I mostly do 430 - 470 g.
    I think it is part of the learning curve to know what YOUR coretto is capable of.
    A lot of folks here will say 2/3rds of bread capacity , but that is a generalisation with way too many variables to be strictly adhered to.
    17,587
    Quote Originally Posted by 5D5A41465D5A51350 link=1261529795/11#11 date=1261956480
    A lot of folks here will say 2/3rds *of bread capacity , but that is a generalisation with way too many variables to be strictly adhered to.
    My personal experiences with 3 different BMs have come in a lot less than this actually, more like 50-60% of what ever the maximum loaf size stated by the maker.... ;)
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    Quote Originally Posted by 382D3A3A31323E315F0 link=1261529795/5#5 date=1261545743
    Jon, I experimented with a Breville big loaf twin paddle and 1.2kg batches but it was hard to control the heat and I ended up withbeans with a charred taste and tipping, I dropped back to 900g and that worked well with better control and ramping etc, but I still find 600g the best for good heat control.
    700gm in winter say 10deg and 750gms in summer in the same BM quoted here with a Ryobi 2000 8-)
    All good
    Jun 2009
    155
    Behmor Coffee Roaster
    Thanks Guys,
    There was no waste as the beans still taste great. Will stick to 500g and under though to maintain a bit more controll.
    Happy New Year to you all too :)
    Phill
  1. My new No.1 Coretto (Mk3)
    By lindsayra in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 20th June 2010, 12:34 AM
  2. My new No.1 Coretto (Mk2)
    Last Post: 18th October 2009, 08:27 PM
  3. Coretto down
    By 22a in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 8th September 2008, 12:09 AM
  4. My $42 Coretto
    By Dr_Beer in forum Roasters
    Last Post: 15th March 2008, 06:05 PM
