Results 1 to 5 of 5
Thread: Drop temp, heat ramp etc ??
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    Apprentice here again.
    Can someone give me a ball park temperature to drop beans in?
    Also some advice on temp gradiant ie:Gas on 80% till start of FC then off, than ramp up 4 mins later. You know what I mean. Obviously there is a dozen or 2 variables but a general shove in the right direction would be awesome.
    (Will stick will 2kg loads for now (looked pretty even)
    Senior Member Dennis's Avatar
    Feb 2007
    4,513
    Re: Drop temp, heat ramp etc ??
    Quote Originally Posted by 7A6D6C7267666D393A39080 link=1266118345/0#0 date=1266118345
    That would be dependent on where the probe is. If youre using a datalogger that generally sits in the bean mass, anywhere between 210* to 225*, again dependent on the bean density. Also, run your roaster for a good 15 minutes before your first load, keeping it hovering at the temps above, as it will stabilise the drum temp.
    Aim for 10 - 12 degrees increase per minute or in other words try getting to 190 degrees between 10 - 12 minute mark (once again depending on the bean density and what you are trying to achieve overall) then 3 - 5 degrees per minute once 1st crack is achieved.
    These are generalisations, I know, but I think a good starting point. You should also try roasting dark, roasting light, with little and lots of airflow, roasting faster, roasting slower, then tast the results to see where you like them or what combinations of roasting suit your tastes.
    Enjoy the journey!
    Sep 2008
    7
    Dennis,
    Ive just done my fourth corretto roast (already onto a second heat gun...), but thats probably one of the most useful posts on roasting temperature ranges ive seen.
    Cheers!
    Simon
    Feb 2008
    1,339
    Quote Originally Posted by 474355464251340 link=1266118345/2#2 date=1286963204
    Dennis,
    Cheers!
    Simon
    Thanks Simon and welcome to CS!
    The next, and perhaps the most difficult challenge when youre getting decent to good results, is to deviate from the above methodology. Unless you do, you will never know if it could be better.
    For example, roast a batch that you already know works well, but this time, when you get to 140 degrees, try increasing the temperature by only 5 degrees per minute till you get to 160, then ramp it up again and follow on as you would normally do.
    You will get a different outcome. Let us know whether you like it or not! ;)
    Jan 2008
    43
    Behmor Coffee Roaster
    Thanks for the words of wisdom Den!
    Ill be following these guidelines too I think; at least hopefully next weekend when the new baby arrives ;D
    Will let you know the outcome!
  1. Killed my Ryobi Variable temp heat gun
    By ozscott in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 10th November 2013, 08:19 PM
  2. Ramp to first crack
    By bassway in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 13th January 2010, 05:37 PM
  3. To ramp or not to ramp ???
    By redzone121 in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 2nd January 2009, 08:08 PM
