Results 1 to 9 of 9
Thread: Thermocouple probe not working?
    Mar 2008
    466
    I ordered the Multimeter from C.S and with it came with the bead type and probe type thermocouple. The bead type works fine but is annoying to use (particularly roasting) but the probe type doesnt work at all.
    Thinking I had a bung probe I ordered a replacement with my latest bean shipment. It also doesnt work. Am I missing something or have I just had two dud probes?
    Jan 2008
    1,756
    Re: Thermocouple probe not working?
    have you tested the probe......with the multimeter? ;D serious...... ;)
    Mar 2008
    466
    Yes that is how i know it isnt working. temperature reading on the multimeter is around 26.1-4 in both boiling water and ice water. if I unplug the probe temp displayed is still in the 26 range.
    I know I am connecting it correctly because the bead type probe I have reads the temp correctly.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 5B7764627F777A495B79787D736F160 link=1269678030/2#2 date=1269736218
    Wgere are you ?
    PM me... Have a meter and lots of bead types... Gave my probe type away with the HT.
    Happy for you to drop over or a quick meet on netural ground ;D
    If it is using the blue connector and not directlt pluged in it can cause issues.
    Jan 2008
    1,756
    i meant continutity or resistance...... ;D
    Mar 2008
    466
    Fixed it. Found the working probe and it was no longer working. That could only be the unit had developed a fault meaning a blown fuse - meaning somebody has borrowed my meter. Fixed with a piece of wire but that connection is no longer fused ohh well. Will be now only on temperature duty (I do have other meters for other uses.)
    Jan 2008
    1,756
    awesome, good to hear.......AM may spit about the non fused fuse though ;D
    Mar 2008
    466
    the worst that can happen is I blow the unit.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Behmor Coffee Roaster
    Quote Originally Posted by 0D21323429212C1F0D2F2E2B2539400 link=1269678030/7#7 date=1269741428
    NO.... If ya get an over curreny or voltage it can cause other problems....
    The fuse is there to protect the user not the device... *Stick the probe in... Turn on unit and then go to select a mode or change the selecter and get SHocked...
    Assumptions can Kill... * Many pieces of test equipment have fuses ... *Secondary issue is protect the device. Primary is to protect the user...
    DO not use under any circumstance for any thing other than temp...
    Use on measuring a voltage etc and your putting ya life at risk.
    Assumptions ?????
    Recite the mantra... AND FOLLOW IT.
  1. Thermocouple probe length
    By Iconiq in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 10th May 2011, 01:03 AM
  2. New Thermocouple Probe for QM1538 DMM
    By Ben_S in forum Roasters
    Last Post: 21st April 2010, 08:22 PM
  3. Probe ...where to stick it!
    By reubster in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 27th November 2007, 09:49 PM
