Results 1 to 5 of 5
Thread: Not getting or not hearing 1st crack
    May 2009
    Hobart
    91
    Hey guys,
    I recently thought that I would branch into the home roasting and give it a try. I have had 2 attempts now with my brazil pulped natural which I bought off here. I am using a heat gun and stirring them myself with a spoon, but will have a BM in a few days time to make it easier! I am not hearing either 1st crack or 2nd crack and then have just stopped roasting after about 20ish minutes.
    I have done 2 roasts now and havent heard anything with either of them, the 1st batch was under-roasted a bit but the second batch was ok, but I just had to go on what I was seeing!
    Is this normal or is there something I am doing wrong!
    Cheers!
    Damo
    Jul 2008
    Port Fairy
    2,993
    Re: Not getting or not hearing 1st crack
    Hi,
    my guess is your not getting the beans to a high enough temp! To go with the bowl setup a cheap digital thermometer that will handle 250 degrees is worth it. Its how I started off a while back. FC will be in most cases obvious and will be a good crackle with your setup. Aim for FC at 10-12 minutes and to finish the roast at 16ish.
    keep playing and remember colour is not everything.
    May 2009
    Hobart
    91
    So maybe try holding the heat gun closer to the beans then? Yeah I think I will invest in a thermometer too. Will have a look in Jaycar over the weekend.
    Jul 2008
    Port Fairy
    2,993
    Sounds like that is your problem, I used to run my heat gun on flat out with the nozzle just above the lip for a start and gradually bring it closer to about 3-4" above the beans till first crack then gradually raise it again until SC.
    What I got was the $40 multimeter with temp probe from Jaycar which works well. Just make a metal clip to keep the thermocouple in the bean mass as you have your hands full with the spoon and gun ;)
    May 2009
    Hobart
    91
    Behmor Coffee Roaster
    Yeah cool, well I will give that a shot over the next few days then and see how we go! Hopefully will be a bit better once I get the BM :P
  1. Hearing FC & SC on a Corretto
    By jacs in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 22nd October 2011, 07:10 PM
  2. 1st crack - 2nd crack timings?
    By tonee in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 12th July 2010, 05:09 PM
  3. third crack?
    By Bidtfaun in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st April 2009, 07:31 PM
  4. First crack & Second crack temps
    By NewToEspresso in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st December 2007, 07:01 PM
