Results 1 to 4 of 4
Thread: Reborn KKTO and Corretto Unloader and Bean Cooler
    Feb 2009
    275
    Hi CSrs,
    Back in October 09 we had the Mk 1 now we Have the Mk 2
    More simple
    More compact
    More professional (well amateurishly so)
    A recycled 10 litre plastic pale and lid in which a metal sieve fitted snugly part way down the pale.
    In the lower half a hole was cut to tightly fit the pickup of a vacuum cleaner
    Another hole was cut in the lid and a piece of similar metal tube was inserted and connected to a flexible wire supported hose donated by a mate
    I partially collapsed the end of another piece of metal tube and fitted the straight cut end into the pickup hose.
    When suction is applied hot beans can be drawn into the sieve to cool them or they could be transferred to a cooler of choice.
    The sieve was $4.50 from a $2 type shop (Hot Bargains, Preston Vic).
    Pardon my presumption KK, but do you think the unloader Mk 2 is KKTO compatible?
    Regards
    Lindsay
    Apr 2008
    Brisbane
    5,117
    Re: Reborn KKTO and Corretto Unloader and Bean Cooler
    Quote Originally Posted by 6762656F786A72796A0B0 link=1274957430/0#0 date=1274957430
    Regards
    Lindsay
    I like it 8-)
    It is only as compatible as your individuality
    If it works for you and you are happy with it then I am smiling with you ;D ::) ;D
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    1,011
    edit - I see the subject line :-)
    Does this do chaff removal too?
    Feb 2009
    275
    Behmor Coffee Roaster
    Hi MattyHo,
    Quote Originally Posted by 2F2336362A71352A420 link=1274957430/2#2 date=1284900179
    Not adequately.
    In my opinion: winnowing is still world best practice for chaff removal.
    Lindsay
  1. Corretto & Bean Cooler Set up - First Roast
    By Sully in forum Roasters
    Last Post: 27th November 2012, 09:59 AM
  2. Thrifty Easy Bean Cooler and Corretto Unloader.
    By lindsayra in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 17th November 2009, 08:10 PM
  3. KKTO and Corretto - Differences?
    By stuartgrant in forum Roasters
    Last Post: 31st August 2009, 11:36 PM
