Results 1 to 10 of 10
Thread: how to get better aroma from behmor?
    Mar 2010
    3
    This is my first post but have been reading for ages. *Ive had the Behmor now just under 2 month, roasting 1/4 - 1/2 lb (but in gram equivalents) every week.
    Ive read all the posts about the Behmor and have followed the instructions and the tips in this forum but Im still getting a flat aroma. *Have tried mostly P2 B 1/4 and 1/2 lb and P3 and P4 (usually with 75%- 90% of rated weight). *Ive gone through all of the CS sample packs and tried leaving the beans in for the full cooling cycle, through to pulling the basket out as soon as I hit the cooling button (but still leaving the machine to continue cooling). *I feel like Im missing something fundamental. Have read and reread the manual and these and overseas Behmor roasting forums.
    Also tried roasting from lighter to darker roasts, but still the aroma is missing. Its lacking from opening the bag, through to the aroma above the cup, and the bland smell from the grounds after emptying the basket.
    The flavour is better than the aroma but I believe it can be better. The lighter roasts were a bit sour so have gone darker. Cant say what CS level yet as I havent got my card yet.
    Any ideas?
    Senior Member Luke_G's Avatar
    Aug 2008
    Northen Rivers
    659
    Re: how to get better aroma from behmor?
    I find the same thing from my Behmor Great Cuppa ..
    I think its just a trait of the machine.
    I did find the aroma a bit better by adding an extra fan faced at the open door once in the cooling cycle.
    Mar 2010
    3
    Thanks Caffeine Dealer, Ill give that a try.
    I read previously there were concerns about cooling down the inside of the oven too quickly if a fan was directed into the oven, thats why I didnt try that before, but Ill see if that improves the aroma. At this stage Ill give almost anything a try!
    Ok what about tips to minimise the "baked" flavour? I didnt quite understand what people meant by that but possibly this is another way to describe the relatively flat taste that Im getting also?
    Is it possible to get a Behmor roasted aroma that smells something like what I get when opening a commercial blend such as a Lavazza gold bag (cant remember the actual product name). Its sweet and light, but my Behmor aromas / flavours are dull, sometimes sour, and flat. Or is this a pipedream for the Behmor?
    Anyway, have ordered more from Andy so more experimentation is in order!
    Aug 2008
    Northen Rivers
    659
    The "baking" people refer to comes from not cooling quick enough. This causes flat flavours and aromas but to drink it...it would taste ok to most people.
    To replicate the aromas of a commercial blend you need to replicate the coffee produced by ther sometimes million dollar drum roasters. Not at all possible with a Behmor.
    The more distinct aromas come from aging the coffee also. If your opening the bag every day trying to smell it then its not going to happen.
    I would look at trying different profiles and weights...add to that some better cooling and youll see some improvement.
    Good luck with it all :)
    P.S. YAY 600 posts :P
    Senior Member Pavoniboy's Avatar
    Jan 2009
    Minnamurra NSW
    693
    I highly recommend making a bean cooler (many designs to be found on here). When you hit the roast level you want - pull out the basket, dump the beans into said cooler and cool in less than one minute.
    It really makes a big difference. No more baked beans ;D
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,353
    Quote Originally Posted by 0332253C3D3A313C2A530 link=1277545763/4#4 date=1277711046
    Ill second that, its surprising how much difference such an easy to construct and inexpensive device like this can make. ;)
    Mar 2010
    3
    Ok off I go a huntin for bean cooler bits.
    A fan of the Fan I have to become! *:D
    Jun 2009
    Moonta SA.
    7,353
    Quote Originally Posted by 2F3A702B3D383829480 link=1277545763/6#6 date=1277808535
    If your looking to buy new bits and pieces you could do worse than Bunnings, they have all you need at reasonable prices. :)
    Dec 2009
    106
    Quote Originally Posted by 053C222C160E490 link=1277545763/3#3 date=1277705412
    I second this. When I first started roasting I was quite disapointed in the lack of smell but I was opening the bag daily giving it a sniff.... Once i heat sealed the bags with an iron and waited at least a week, I was shocked at the difference.
    Nov 2008
    62
    Behmor Coffee Roaster
    Quote Originally Posted by 5A425A05435F455252370 link=1277545763/8#8 date=1277854196
    I second this. *When I first started roasting I was quite disapointed in the lack of smell but I was opening the bag daily giving it a sniff.... Once i heat sealed the bags with an iron and waited at least a week, I was shocked at the difference.
    I third this. Often, with the Gene Cafe, there is very little aroma post roast, so put it away for 5+ days and its fine.
  1. Replies: 6
    Last Post: 12th July 2012, 10:19 AM
  2. Aroma, Aroma, Aroma... Where art thou..?
    By youngchul76 in forum General Coffee Related...
    Last Post: 1st January 2012, 09:19 AM
  3. Aroma in beans roasted in Behmor
    By bmawebb in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 24th August 2010, 05:24 PM
