Results 1 to 3 of 3
Thread: Questions after first roast..
    Senior Member bennett's Avatar
    Jan 2008
    294
    Had my very first roasting experience tonight after receiving my Peru Ceva Estate from Andy today.
    I tried 100g in a popper. Ambient temp was about 20 degrees.
    First crack started about 2:40m finished about 4 min mark then second crack started about 5 min and I pulled them out about 20 sec into second crack. Cooled beans in two colanders till cool.
    My questions are
    1. I coaxed the beans along with a wooden spoon. They were moving ok, but at times sluggish. Should I be stirring constantly to keep them moving, or should I roast less quantity so they move independently?
    2. The result looks ok but quite uneven, is that potentially because of lack of movement or popper too hot. It all happened so quick from start to finish. Should I modify things as recommended in other posts eg drill holes use extension cords or tilt popper etc.
    Anyway it is all very addictive and if I had time now, Id be outside practicing with the remaining 2.4kg of green beans* ;D
    Mar 2004
    Internet
    16,845
    Blog Entries
    1
    Re: Questions after first roast..
    Quote Originally Posted by 3C3B30303B2A2A5E0 link=1321356814/0#0 date=1321356814
    Welcome to the other side Bennett!
    in short... yep!
    You will read 1000s different takes on "correct popper roasting" here on CoffeeSnobs and the only right answer is the roasting method that works for you. Each pooer and environment is different, you couls have two poppers side by side and they will roast differently... these are not scientific tools!
    My suggestions for first time roasters in a popper:
    1. Use 80g of beans (fill to the top of the "shark fins" in the base of the popper if you dont have scales)
    2. Turn it on
    3. Turn it off at the first snaps of second crack and cool them.
    Thats it.
    The result looks ok
    Cmon, from that pic they look pretty amazing... well done. Look to be a great roast depth and should come-up well after a day or two rest.
    Both. Slow moving beans in a popper will roast uneven but having said that, sometimmes those roasts taste great as if becomes a wider band of roast depth and flavours.... like a 4 roast single origin blend really.
    Nup... plenty of time to play later. Try with fewer beans and the time will extend a little. Dont get hung-up on the actual time or try to hit a target, instead slow it down enough so the finish time is less frantic and that will give you more control over when you stop the roast.
    all very addictive
    Even more so after you try the coffee.
    Take lots of notes so you can replicate (or avoid) the same technique later, roast plenty so you can rest it over a few days to find where you like it best... and most of all...
    Enjoy the journey and the learning
    Jan 2008
    294
    Behmor Coffee Roaster
    Quote Originally Posted by 022D273A430 link=1321356814/1#1 date=1321367770
    I thought we were talking about coffee not toilets. ;D
    Quote Originally Posted by 7F505A473E0 link=1321356814/1#1 date=1321367770
    2. Turn it on
    Thats it.
    Thanks Andy, I needed some concrete beginner advice to begin with.
    Thats exactly how it was, really frantic at the end. One thing I can say is that the cracks were really easy to differentiate.
    As always Andy, thanks for taking the time to help out a beginner, much appreciated. :)
  1. Baby Roaster - First roast - Technical questions
    By coffee_mogul in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 20th January 2012, 11:12 AM
  2. First roast questions
    By dbd in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st May 2011, 06:54 PM
  3. Corretto roast questions
    By g8rgrad2k in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 1st August 2009, 12:58 PM
  4. i-Roast 2: questions
    By catwoman in forum Roasters
    Last Post: 18th May 2008, 07:39 PM
  5. Heatgun roast questions
    By steve in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 19th October 2006, 11:55 PM
