Results 1 to 2 of 2
Thread: Baby Roaster - First roast - Technical questions
    Mar 2007
    59
    it has been a long time between posts on here.....
    Ok......firstly a big thanks goes out Den at cuppacoffee,
    for sourcing the Baby Roaster so quickly.
    Every transaction with you has been so easy, you are a true gentleman and a pleasure to deal with.
    On to my technical question....
    I have run one roast of "Harrar", all went well.....about 11 mins to second crack, but with a fair bit of tipping..... If I am more cautious with the heat, I am sure the roast will be spot on.
    What I did notice was the copper drum seems to have expanded and the handle/drum "plug" seems to be inside the drum further. This has caused a bit of a gap between the drum & "plug". The gap is big enough for beans to exit the drum, or get jammed during roast, preventing the "plug/handle" from being removed easily to check the roast.
    Has anyone else noticed this?
    Oh, and its great knowing someone here will likely have an answer......
    Mar 2011
    76
    Re: Baby Roaster - First roast - Technical questions
    Behmor Coffee Roaster
    I have experienced the beans getting caught, but that is usually only when I do a Yemen roast (small bean) I think I will start a thread based on the Baby Roaster techniques with hopes of everyone that uses one adding there own tips and tricks
    Edited to add: or maybe Ill just post in the one already there hehe
  1. FZ-RR 700 Baby Roaster
    By Gra in forum Roasters
    Last Post: 22nd August 2017, 09:36 AM
  2. Technical Questions on La Pavoni
    By paulvin in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th July 2011, 08:11 PM
  3. !!!SOLD!!! - FZ-RR-700 Baby Roaster
    By Beanz. in forum SOLD
    Last Post: 7th October 2010, 10:32 PM
  4. Baby roaster v Behmor
    By yxoc in forum Roasters
    Last Post: 26th September 2010, 10:41 AM
