Results 1 to 10 of 10
Thread: KKTO roasting times
    Dec 2006
    148
    KKTO roasting times
    Had the kkto for a while now, noticed it was taking longer for a roast - 300-700 so normally around 20 mins tops. Thought it was my Tiffany, so picked up an easy cook - also fire blanket (got spoilt), last roast 600g took that long my tempered went off, sure it was almost 25-30 mins. Takes forever lately - coffee is still good. Is there excessive heat loss maybe ? Will check seals and clean bit nothings changed.
    Apr 2008
    Brisbane
    5,113
    Re: KKTO roasting times
    Since you are a local Brisbane lad
    I am happy to have a look at it for you
    Dec 2006
    148
    Cheers kk - only thing I can see is the tubing is loose - got some high temp, gasket. PM if you around to catchup or provide any things to try.
    Nov 2006
    1,077
    I had the same sort of issue after about 200 roasts so a bought a cheap Aldi turbo oven and started using that, roast times were shorter but not as originally available with the original tiffany.
    All other variables remained the same.
    Mal
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by 5C4C404343405F5C2F0 link=1329526314/2#2 date=1329534058
    Cheers kk - only thing I can see is the tubing is loose - got some high temp, gasket.* PM if you around to catchup or provide any things to try.
    Yes I do have some High Temp silicone - the copper based stuff
    I use this or the red type for sealing the liner
    Quote Originally Posted by 4D40434D2F0 link=1329526314/3#3 date=1329537557
    Mal
    It is important to keep the fan & element clean
    Chaff - even if its a tiny amount, will find its way into the upper section of the TO system
    With repeated use it may build up
    " When Cold" I regularly vacuum or blow air through the TO
    This keeps it as clean or at least dust free
    Dec 2006
    148
    Ok cleaned the tubing - resealed with RTV red. Brand new Turbo oven so no need to clean yet. First roast was about 500g - had my temp monitor on. Again went off as it took so long. I am guessing 20 minutes idle ? - so good 20 odd minutes for roasts...I am thinking maybe the Tiffany had more guts than the easy cook ? Just over time my was failing perhaps ?
    Thoughts on easy cook against Tiffany (other than cost). I havent seen anything much like a 1400 watt motor I think the Easy cook is 1300 675 model ?
    Apr 2008
    Brisbane
    5,113
    What beans are you using
    Most hard or high altitude beans will take 20 min beans
    Dec 2006
    148
    My usual is Ethiopian, Sumatran, few centrals - swear it was under 20 - never had meter go off whilst roasting. Still good though dont get me wrong.
    Nov 2010
    369
    more insulation?
    Dec 2006
    148
    Behmor Coffee Roaster
    Hmm never had the problem until I changed the TO. I also added a fire blanket so if anything done that too.
  1. Roasting times
    By Timothy.McIntosh1 in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 28th November 2010, 06:19 PM
  2. Roasting with KKTO
    By Lacehim in forum Roasters
    Last Post: 11th February 2010, 12:04 AM
  3. Roasting times for small batches ?
    By redzone121 in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 27th October 2009, 12:08 PM
  4. Roasting times/temp
    By bassway in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 3rd February 2009, 07:54 PM
  5. Indian Mysore Roasting Times
    By kevviek in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 19th June 2008, 10:30 PM
