Results 1 to 3 of 3
Thread: Plastic in coretto pan
    jekoff
    Ive just setup my "coretto" roaster and I"ve done a couple of roasts which were pretty ok, but smells strange.
    I have seen that its plastic inside the pan ( in the hole below the paddle ), and I tried to get it away by using a knife. I managed to get almost everything away except a little.
    Have anyone had the same problem and how is it possible to get rid of everything?
    Maybe I can use the heat gun to burn it away? Or will it be hard to get the burnt plastic/smell away afterwards?
    All hints welcome :)
    Here is an image, its the red plastic in the hole i want to get rid of in some way. Its so narrow there so i cant get everything out with a knife.
    Apr 2008
    Brisbane
    5,113
    Re: Plastic in coretto pan
    That is the Teflon coating
    Most consider it a health risk & recommend that you remove the lot from the entire pan
    jekoff
    Behmor Coffee Roaster
    Ok i will try to remove to teflon with sandpaper. But if you look closely in the hole , there is a red plastic ring around the hole which is impossible to get away with a knife. Do you think its possible to burn it away?
  1. This is why plastic inserts in your handle are bad...
    By nwood in forum Brewing Equipment (non-machine specific)
    Last Post: 19th April 2013, 09:04 PM
  2. Diadema / BFC Junior - Hot Plastic Like Smell?
    By moreCoffee in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st November 2010, 01:40 PM
  3. EM6910 plastic insert
    By doff23 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th April 2010, 04:18 PM
  4. Ive gone to Plastic Storage....your thoughts !
    By redzone121 in forum General Coffee Related...
    Last Post: 26th October 2009, 03:44 PM
