Results 1 to 12 of 12
Thread: Home roasting database
    14,665
    Hi all- have grabbed a copy of this nice looking database which may be of interest. Wonder if it works??? You can supposedly log pretty much everything including inventory, roast details, blends and a whole heap of other things. It runs in MS access and is about 0.5MB....avalook if you feel inclined.... http://improbablystructuredlayers.ne...B/CRDBHome.htm *NOw...time to experiment :)
    Dec 2004
    Earth!
    16,312
    Re: Home roasting database
    Hhhmmm...Ill have to check that out. Ive been using an Access/Excel database/form I made to track my roasting. Ive ended up not using a lot of the fields I originally put in and adding others.
    Java "If you dont track it you cant repeat it" phile
    ed_vinas
    This looks great, better than the spreadsheets Ive been keeping. Thanks for sharing the link.
    Ed
    Dec 2004
    Earth!
    16,312
    Nice database set-up indeed. Now to mod it to track a few more things. ;D
    Java "I love playing with new toys" phile
    Dec 2004
    485
    I should have taken a closer look... but does it work on Macs?
    Jan 2007
    Perth, Western Australia, Australia
    791
    I found another Roasting Database program searching the web.
    this is not long upgraded and also has a cupping database as well. Thought someones else might find this useful.
    Roasting Database
    http://homepage.ntlworld.com/green_b...newversion.htm
    Cupping Database
    http://homepage.ntlworld.com/green_b...cupversion.htm
    hazchem
    oh wow, thats just awesome, thanks for the links! I was going to try and build something like this in openoffice but it would have been pretty rural compared to this.
    not too much existing data to transfer from spreadsheets and Im pretty sure itll be worth it.
    Jan 2008
    1,756
    Quote Originally Posted by 657974767E7E75787462110 link=1113135726/5#5 date=1248681742
    Roasting Database
    http://homepage.ntlworld.com/green_bean/coffee/coffeeroastdbnew/newversion.htm
    This is awesome! very comprehensive for what im after!, i have been maintaining paper copies of all my roasts, this will be so much easier to reference back to for future, as long as i dont loose it ;)
    Jun 2009
    80
    Quote Originally Posted by 627970637A737E68110 link=1113135726/4#4 date=1113302517
    No, its a Microsft Access database so Windows and MS Office only Im afraid.
    The second database is JAVA based so will work on most anything I would think.
    Jeff K
    hazchem
    Quote Originally Posted by 7D7271717C170 link=1113135726/8#8 date=1248943099
    This works fine on on my Macbook Pro with an Intel processor. Had some problems at first getting it to run as I didnt have the right Java Runtime Environment priority set but now its all working fine. Im loving this software!
    Mar 2008
    433
    only thing im not liking is that you cant manually input the times for the roas session (or have I missed something). Under the "Sessions" form, easy enough to select the inventory, amount and set roast level, but if you want to record the timing of the roast, you have to simulate the roast again (unless ofcourse you have this running on a laptop and activate it as you roast)
    Sen
    hazchem
    Behmor Coffee Roaster
    Quote Originally Posted by 7D4B404F5A415C2E0 link=1113135726/10#10 date=1251595894
    Sen
    Im not sure what you mean Sen. I input all the data as I go, with a pen and paper for backup in case it all gets too exciting. I know that not everyone has a laptop they can take to where they roast, but regardless of what spreadsheet or software youre using, if you dont log the data as you go, arent you essentially "simulating the roast" again every time you enter the data post-roast?
    apologies if Ive misunderstood.
  1. home roasting into commercial roasting
    By drink1121 in forum Roasters
    Last Post: 28th September 2012, 11:36 PM
  2. I want to start home roasting
    By kanda712 in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 12th June 2011, 10:53 AM
  3. Home Roasting
    By Gra in forum General Coffee Related...
    Last Post: 11th December 2008, 12:10 PM
  4. Roasting Logbook / Diary / Database
    By thegoodies in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 23rd May 2007, 09:52 PM
