Results 1 to 5 of 5
Thread: Didnt hear the crack
    Dec 2004
    9
    I did my first roast last night using a popcorn maker and i didnt hear the first or second crack, my popper does roar a little but i thought the crack would be as loud as popcorn.
    i ended the roast at 22 mins when i thought it smelt done how long should i let the beans sit after roasting i thought about 24 hours so im going to grind and brew tonite
    will let you know how it tastes
    Mar 2004
    200
    Re: Didnt hear the crack
    22 minutes in a popper! What size batch were you using? Were the beans moving on their own or did you have to stir? I cant recall popcorn noise too accurately but I can always clearly hear distinct first and second pops in a popper though some beans crack louder than others.
    The last time I used mine (xu1 heat gun died this week mid roast *:( ) it wanted to hit first crack after 2-3 minutes. I have found light shaking to be useful in preventing to rapid a roast but thats not your problem.
    Strongly suspect your popper is not operating in spec. 22 minutes straight at "normal" heat would also be very hard on the machine.
    17,547
    Hi,
    It might not necessarily be a bad thing. If your bean load is too light then the requisite roasting temps might not be developed. Try increasing your bean load by 10 -20 grams at a time until you achieve a more realistic roast time (less than 15 minutes all up) and distinct periods of first and second crack.
    You might find that you have to tilt your popper over (away from the discharge chute) to prevent unwanted loss of partially roasted beans and to assist bean movement in the popper chamber. Ive got a "Tiffany" Popper and have found that I need to tilt it over about 30 degrees to achieve a satisfactory outcome with a load of about 110 grams of beans.
    Depending on the beans being roasted, the all-up roasting time can vary between about 8 and 12 minutes with my setup so youll probably just have to experiment a bit to get it right. My first Popper used to have all roasts finished in less than 7 minutes and with a couple of batches of Santos beans I had, in less than 5 minutes. It eventually turned out to have a faulty Fan Motor though, didnt push a big enough volume of air through the roasting chamber. Sounds like yours is doing ok though. All the best,
    Dimal.
    Mar 2004
    Adelaide
    9
    Hi,
    I had similar problems before with poppers. Fix the problem by disabling the thermostat. If the popper thermostat is not disabled and ambient temperature is low it just cant get to temperature. This is due to the thermostat cutting out.
    The other problem with poppers is that the fans start to slip after a few batches. Gave up on poppers now. Have been using heatgun and now turbo oven.
    Happy roasting
    Kopi-O
    Dec 2004
    9
    Behmor Coffee Roaster
    Aha theres lies the problem, being my first roast i only did 30grs of beans not wanting to ruin large amount so they were spinning flat out i shall get a thermometer and try again with 100 grs
    the popper is a tiffany and a tad old but its only till i get a roaster (for chrissy i hope)
    Thanks Guys for the guidance and help
    i still ground and brewed it, it was very weak and slight burnt flavour
  1. Now Why Didnt Anyone Else Think Of This Before!!!
    By ezralimm in forum Milk Froth and Bubbles
    Last Post: 5th June 2010, 06:46 PM
  2. Replies: 6
    Last Post: 14th September 2009, 07:00 AM
  3. One I didnt know about....
    By TC in forum Brewing Equipment (non-machine specific)
    Last Post: 28th May 2006, 10:52 AM
  4. Could not hear first crack (Gemadro)
    By warren in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 19th October 2004, 07:11 AM
