Results 1 to 11 of 11
Thread: woodfire roasting
    Senior Member summercrema's Avatar
    Mar 2008
    266
    woodfire roasting
    the method of Woodfire Roasting coffee bean has it been around long, what do people think of it? Using different kind of heat or fire to roast the bean. Any comment out there?
    Nov 2006
    1,077
    Re: woodfire roasting
    What size fire would you need to consistently generate heat of over 200deg?
    Mal
    Apr 2008
    Brisbane
    5,115
    Quote Originally Posted by summercrema link=1221295574/0#0 date=1221295574
    the method of Woodfire Roasting coffee bean has it been around long, what do people think of it? Using different kind of heat or fire to roast the bean. Any comment out there? *
    Its probably the first ever method of roasting
    I believe this original method is still used today commercially in the Middle East
    There are some boutique companys in Sydney that also woodfire roast coffe
    Edit
    Yes that leaves another question??
    Would the wood smoke penetrate the bean while roasting giving it a different taste in the cup?
    Mar 2007
    123
    http://www.youtube.com/watch?v=6af86IX9RdM
    Its the original method!
    CHAD
    Apr 2008
    Brisbane
    5,115
    Here is a pic of a woodfire oven
    Looks cool/hot??
    U know what I mean
    Jul 2008
    Blue Mountains
    136
    I watched a video on youtube of a bbq roaster on a rotisserie in his bbq, so i think that if you are lucky enough to have wood fired pizza oven you coud rig up a rotisserie on the outside with the drum in the pizza oven, you could easily get the temps needed. Thats what I am planning to do anyway, and cook pizza of course, you cook pizza up around the 300 to 400 mark, so if anything it might get a bit too hot. Just got to build the pizza oven, but there pretty expensive from what I have seen of them on the net. But i think it would work really well.
    b
    b is offline
    Aug 2008
    77
    Would a drum be essential? Weve got a pizza oven that runs 200 to 320C* and sort of controllable to within 50C, so the temperatures are in the ball park. However, there is no way on Gods earth Id be allowed to drill holes through the side of it. Could the beans be laid out on a tray or directly on the stone hearth with shaking or poking with a stick?
    *according to the built in oven thermometer, must be accurate to oooh, 10%?
    Jul 2008
    Blue Mountains
    136
    put the drum in the oven through the front door, then have the rotisserie siting outside the oven, whith a s/s support in the oven. It could be done, its all in my head though, hopefully it will get out one day.
    Feb 2008
    1,339
    Quote Originally Posted by ž[ch945
    [ch8467][ch273][ch915][ch1209][ch1179] link=1221295574/0#6 date=1221446616]Would a drum be essential? Weve got a pizza oven that runs 200 to 320C* and sort of controllable to within 50C, so the temperatures are in the ball park. However, there is no way on Gods earth Id be allowed to drill holes through the side of it. Could the beans be laid out on a tray or directly on the stone hearth with shaking or poking with a stick?
    Hi baldryk
    While a drum wouldnt be essential, it would be desirable...if for no other reason it would keep the beans agitating.
    Rather than the oven, I think a frying pan over a hotplate would be preferable as it would allow you to have better control over the temperature, agitation, and dumping the beans once theyre roasted. The challenge you face with either method is to try and not scorch the beans. It might help if you think of it in terms of cooking - brown on the outside and rare on the inside can be ok for meat, but not so good for coffee.
    Either way, give it a go - you know you want to!
    Jul 2008
    Port Fairy
    2,993
    Just a possible problem with the oven thing chaff hitting the bottom element catching fire *:o not to mention potentially smoking up the house and becoming really unpopular *;)
    Might be nice to have smoked beans with sandlewood kind of like having syrup coated beans
    Slightly more seriously you would want a fairly smoke free fire from a clean burning timber, a little smokey flavour might be nice but it would be easy to overdo it.
    May 2007
    6
    Behmor Coffee Roaster
    I been using that method for a while now in our shop for something different and best of all, at home. It is great! We have many people ask when I will roast using that method.
    I use all types of green coffee with success, even pre blended beans.
    I use wood, briquettes, hot plates.
    Roasting is done in cast iron skillets and pots or even campfire popcorn roasters.
    Any steel or iron that wont melt at temp works - but it should be a safe and clean material.
    It does have a different flavor and usually a great body when brewed correctly.
    I stir the beans constantly by hand and by shaking the cast iron skillets and pots.
    I am using cherry, apple or hickory wood to "smoke the beans" first and while actually roasting.
    Try it, it is great! I love roasting this way.
    Anyone wanting more info just email. I am located in the state of Idaho, USA.
    graybeard42@roadrunner.com
  1. Pros & Cons - Air Roasting versus Drum Roasting
    By Dolcimelo in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 9th January 2013, 10:37 PM
  2. home roasting into commercial roasting
    By drink1121 in forum Roasters
    Last Post: 28th September 2012, 11:36 PM
  3. Cast Iron Pot roasting…gas fire roasting
    By colombiasmoothbean in forum Roasters
    Last Post: 17th May 2012, 05:17 PM
