Results 1 to 24 of 24
Thread: 1st heat gun, bowl & spoon home roast
    Jun 2008
    1,520
    just roasted these out the back for a try, never tried bowl and spoon method before.
    beans Ethiopian Yirgacheffe from beanbay
    estimate 250-300 grams (i dont have scales)
    roast took around 15 mins 1st crack i think around 10ish
    to make it easy i used my old homebrew bottle capper as a HG stand.
    ryobi heat gun from tool box, 1800 watt two settings high and low
    i used high for the whole roast, apart from right at the end to just take them into 2nd crack a bit
    seemed very easy easy to hear 1st and 2nd crack, 2nd was "pre-empted" by a fair amount of smoke started coming off.
    will ad a fan to blow chaff away a bit for next roast as the odd bit blew into the gun for a tracer effect *;)
    pics
    set up
    post roast cooled
    beans close up, 1 flash 1 no flash pic
    here is a compasision of the same beans roasted at Saturdays Sydney meet up in Hazchems Gene cafe, beans on left from gene cafe, notice 2 beans on right (todays) in the middle section about 6 beans down have little "pot holes" i picked these out to show them but could not see many in the fresh roast.
    they look good to me (not much experience home roasting)
    best part was this was so easy...... hope they taste good :)
    Leeham
    Jun 2008
    1,520
    Re: 1st heat gun, bowl & spoon home roast
    did a 2nd roast today
    added a pedestal fan to the set up to blow chaff, ran it on high for a while, but dropped it to med as i think it was effecting the heat a bit much.
    I reckon if your thinking of a popper this might be a way to go, even better if you have a heat gun in the shed *;)
    estimated roast size +-420grm
    result was 350 grms of roasted bean, took it to the shop to weigh :)
    fan increased the roast time by blowing away some heat
    rolling 1st crack about 15 mins.
    pulled just into 2nd crack about 22 mins
    i need to get a timer now.......
    again 1st and 2nd crack easy to hear and smoke before 2nd
    might be some tipping, experts Home Roasters might advise me on the pics. i have circled what looks like tipping in red circles in the 1st picture?
    pics
    10,496
    The fan can affect the roast times.
    Jun 2008
    1,520
    yeah TG i had a breeze today to compared to 1st go so that would have had an impact to. But was offset a little by a warmer day.
    I am just having a bash, no real science behind my roasting :)
    next step is simple mixer of some sort or put a handle / holder on the bowl, gotta look in the tool box for something to pull to bits. hand was getting a bit hot holding the bowl *:-[
    would be better to have two free hands
    got an opinion on the tipping, you know your roasts.
    BTW the kimmel is very nice :) thanks again
    Jun 2009
    12
    maheel,
    I tried the bread machine first, and then went to a little quieter hands-on method like what youre doing. *Figured I could always go back to learning the BM method later. *I copied a method described on the home- barrista forum by member RAS. *You place a steel mesh colander inset into a stainless steel bowl so that there is an air gap between the colander and the bowl. *The rim of the colander rests on the outer rim of the bowl so it does not move while stirring the beans. * I hold the heat gun in my left hand and stir the beans with a wire whisk in my right hand. *I wear a pair of gloves to protect from the heat.
    The mesh container helps keep the heat absorbed only by the beans and not the container so they are easily brought up to temperature. *I tried heating them directly in a ceramic bowl and it did not work because the ceramic bowl absorbed too much of the heat from the beans.
    This method is a very easy and relaxing way to watch and hear the roasting process. *Im roasting about half pound or 250g per roast. *FC is usually at about 10min.
    I know this is somewhat primitive to what others are doing, but I enjoy it and am getting great results.
    Jon *
    May 2009
    174
    I am thinking of going the Coretto or KKTO way, but for now I am also quite happy with the results of my "Cormano" setup :)
    Jun 2008
    1,520
    Hey all, i have not roasted any more yet, for fathers day *i was given a couple of bags of Tobys estate. Good to see a "roasted on" date sticker on their bags
    But i need to do a roast over the weekend to keep up supply of some beans with a weeks (or so) "rest".
    only MOD i will be doing is something to hold the bowl for me so i dont have to hold it.
    was thinking a cheap pair of "vice grips" to lock onto the rim of the bowl and attach them to the heat gun setup?
    That would allow rapid removal of roast bowl for cooling and will give me a spare hand *
    i also have a digitial timer now so can take time better :)
    its such an easy way to get a roast happening with a good batch size, I will look for a stirring motor but am not wanting to over capitalize in this "roaster" I had a laugh not sure how long my old heat gun will keep going, time will tell *:)
    Leeham
    Jun 2008
    1,520
    completed another roast Sat night, all went well
    FC about 17mins
    SC about 22 mins
    about CS 9-10 i reckon
    did not get the smoke prior to SC this time? (or could not see it)
    got a bit worried as it seemed to take a while to FC but may have been cause i was watching the timer? They look ok, the others i am drinking from the other batch taste good :)
    have not sorted the "holder" yet, but have found a possible *"motor" for the stirring drive, not sure if going to make it "remote control" :) or use the sewing machine motor ? Found these on the curb on the way home at lunchtime, both work fine :)
    nice bit of freeganing *:D
    2nd pic is the sewing machine motor stripped out but might put it back into the machine and use the belt drive setup inside striped down a bit as at low rpm torque seems low. but then i would have more parts to cause problems.....
    i like the idea of two speed (play / fastforward) of the VCR so will pull that apart later for a play *;D Might be quality as it was made in Japan!! I had a laugh
    leeham
    May 2009
    180
    Talking of freegaining, have you seen / tried Freecycle ?
    A way to recycle that which you have no use for, yet cant be bothered to try and sell. Or indeed, find someone elses trash which could be just that piece of treasure you have been searching for.
    Admittedly there is a lot of crap that gets posted, but once in a while something worthwhile goes up.
    10,496
    Freecycle is where I scored some BMs for converting to Correttos.
    Jun 2008
    1,520
    pulled the VCR to bits, not much inside :( the video heads are interesting but, the electromagnetic drive system and magnets have been kept as they might prove interesting.
    one little eject electric motor, but i dont think it would be worth the effort
    Bit of brass bushing and all the screws have been added to the the screw box.
    the sewing machine is looking the best bet for a drive motor
    might have to join freecycle for a look
    Feb 2009
    275
    Hi Maheel and CSrs,
    I have an old cake mixer Ive been intending to try as a bean stirrer it has a speed control, is made to turn two beaters or dough hooks, but just one customised stirrer is how I imagined it may be useful, not sure about torque (its not a Kenwood).
    The stirrer could be made with a long shaft to keep the motor unit away from heat, or a speedo cable may work as a long flex drive for a stirrer.
    Car electric window winder motor or wiper motor and drive may be other possibilities if 12V is available.
    Jun 2008
    1,520
    Hey KL, have not seen you post for a bit, where you been hiding?
    i like your idea
    i was thinking about one of the cake mixers that "turns the base" as well. I was thinking you could just have a adjustable stirring arm and let the base turn the beans over it? But the beans might just get pushed around the bowl instead of mixing?.
    what about a HOBART dough mixer? Need a BIG heat gun for one of those!!
    My thoughts headed towards a cement mixer style set up, where the bowl is rotated on a axis with internal blades to stir and roll the beans.
    I freegand a working vacuum cleaner yesterday from the curb, that is going to be my bean cooler soon. Interestingly inside the vacuum is the part that "returns" the extension lead. It allows the lead to wind in and out but keeps the power in contact via a couple of copper discs / circles and spring loaded brushes. This part may prove interesting for my "cement mixer roaster" idea.
    sadly slow progress i being made, i have started painting the new house inside, not alot of shed time is avialable.......
    Leeham
    Feb 2009
    275
    Hi Leeham,
    The frown squad have a hit out on me for joking around, so Ive been under the bed for a few weeks (Im the sensitive type).
    Love your wild roasting thoughts, a bit of comic relief is good for the soul (but not everyone has or apparently needs a soul these days).
    Im still using my thrifty vacuum cleaner driven Hot Bean Cooler Mark 2 though the cooling chamber is now complements of Nestle (Milo tin).
    http://coffeesnobs.com.au/YaBB.pl?num=1238024012/0#0
    Very fertile roadsides out your way, perfect for your improvising and lateral thinking ability.
    No rush, all in the fullness of time.
    Keep up the stimulants and enjoy the home journey too
    Anon
    (you dont know me thats not me with the false beard,wig and Kevlar vest).
    Jun 2008
    1,520
    I had a laugh welcome back KL , your time away has been well spent with your thrifty vacuum cleaner bean getter idea.
    Today i joined the dark side with the purchase of a $15 breadmaker
    i think it may need modification as it is a Breville BeanBay-200 "bakers oven" The manual tells me it only dough cycles for 10 mins and has a pulsing action at the beginning.
    sadly the motor from the sewing machine proved to not have enough toque at low RPM, but it has provided plenty of bushing / grub screws material to play with.
    pictures and modifications to follow :),
    happy days
    Leeham
    May 2008
    4,266
    Quote Originally Posted by 232F262B2B224E0 link=1251955423/14#14 date=1254968911
    You will need to mod it. I have a BeanBay-200 and it pulsed for 12 mins - stops for 5 then continues for another 15 or so - or it did until I had the mod done.
    More info here
    Jun 2008
    1,520
    thanks Flynn Aus :) opening your link NOW !!
    leeham
    Jun 2008
    1,520
    So i pulled the BM apart and hardwired the motor, no switch yet just direct to the power cord. i have removed all the electronics near the motor etc and the heating element as well from the roast chamber.
    works well and easy to do once you get it all apart
    if anyone knows what the 2 temp probes are on the side of the "baking housing" *can you tell me please.
    I was wondering if they are thermocouples and if my PID will read off them. Will try later :)
    sorry did not take a pic
    here is a little idea i had, quick mock up of some parts......:)
    not sure if it would work? will need a new lid but !!
    but an interesting idea,
    BM & popcorn maker heater
    will do real a build thread once finished
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 424E474A4A432F0 link=1251955423/17#17 date=1254985431
    I was wondering if they are thermocouples and if my PID will read off them. Will try later :)[/b] sorry did not take a pic
    All I see is DANGER DANGER - 240V every where and NO SAFETY..
    Jun 2008
    1,520
    its not plugged in............
    the 2nd shot shows it all back together after the wiring mod
    i didnt run the popper motor on there, that would be crazy. I had that motor pulled out of a popper as the shell of it stank of i dont know what
    but yes AM, i agree there is cause for concern when playing with 240V
    how was your law exam? that subject was one of a few i got a distinction in.... i did that subject at Griffith in the holland park area uni
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 4448414C4C45290 link=1251955423/19#19 date=1255001395
    in the second shot there are Brown and Blue wires exposed and switch terminals = Live or the wrong wires being used ???
    Contractors Licence / Small business law etc 41 out of 45... I would argue that 2 of those I got wrong was because of the wording and interoperation..
    IE. If the Principle Inspector signed off on teh work that was performed by another would the Electrical entity have grounds to suspend.
    I said YES... They wanted NO.
    The answer was that they can sign off on any thing.. The issue is that they would have to manage the risk and if deceit etc came into play... In addition the fact that they signed off is also not a criminal act
    Thus they can sign any thing...
    It was a little like the old trick question..
    "supercalifractious-expialidocious" now spell it.. With the answer being "it".
    Jun 2008
    1,520
    i might be thinking about "contract law" ie business / accounting
    not contractor law that you might be doing
    anyway well done on your marks
    and good spotting on the wires, thats just how i ripped it out of the popper case to throw on the "might keep that pile"
  23. #23
    Feb 2009
    275
    Hi Leeham,
    You wrote:
    if anyone knows what the 2 temp probes are on the side of the "baking housing" can you tell me please.
    I was wondering if they are thermocouples and if my PID will read off them. Will try later sorry did not take a pic.
    They will be over temp devices and probably of no current use.
    Again we seem to be travelling parallel paths (see tonights post pre midnight)
    Kind Regards
    Lindsay
  24. #24
    17,573
    Behmor Coffee Roaster
    Quote Originally Posted by 717473796E7C646F7C1D0 link=1251955423/22#22 date=1255008757
    Hi Leeham,
    I was wondering if they are thermocouples and if my PID will read off them. Will try later *sorry did not take a pic.
    Kind Regards
    Lindsay
    Agree Lindsay....
    Likely to be thermistors, not t/couples or RTDs, etc...
  1. First Roast in a Mixing Bowl
    By beanflying in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 4th September 2008, 03:23 PM
  2. Would this work well? A heat gun + mixing bowl?
    By jatzntan in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 31st July 2008, 07:39 PM
  3. Great bowl for heat gun roasts
    By Ron in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 26th May 2007, 07:51 AM
  4. Heat guns; never leave home without one
    By mauricem in forum Roasters
    Last Post: 14th December 2004, 10:26 PM
