Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By blueseas
Thread: Active carbon filter for roaster
    Jun 2009
    4
    Has any one used an active carbon filter for smoke & odour as an after burner can cost as much as a roaster?
    Feb 2008
    1,339
    Re: Active carbon filter for roaster
    Quote Originally Posted by 313630232129273031420 link=1282127521/0#0 date=1282127521
    Yes, and they dont work.
    I invested $2.5k finding out and you got it for free with your first post on CS.
    Welcome to CS and repay my information by going out and doing something nice for someone else.
    You can call me on 0404 049 812 if you have any other questions about it.
    Jun 2009
    4
    so what is a cost effective solution (not half a jet engine ) .have you tried a water scrubber or a catalytic combustor similarlily used in american wood fired stoves?
    Jul 2008
    Port Fairy
    2,993
    Electrostatic seems like a good option combined with some other filtration. What size roaster are you looking at?
    http://en.wikipedia.org/wiki/Electrostatic_precipitator
    Feb 2008
    1,339
    Quote Originally Posted by 33343221232B253233400 link=1282127521/2#2 date=1282137167
    Quote Originally Posted by 2225212E262C39292E27400 link=1282127521/3#3 date=1282138760
    A critical question.
    If you dont want to call me, call Mark from Coffee Roasters Australia.
    May be a good option but a very expensive one!
    Jul 2008
    Port Fairy
    2,993
    Quote Originally Posted by 2432373726242821212222470 link=1282127521/4#4 date=1282167047
    expensive one
    Expensive to buy from what I have found but compared to afterburners cheaper to run. Should be quieter too ;)
    May 2010
    Sydney North Shore
    1,325
    There was an interesting acoustic carbon filter system that won the ABC New Inventors last night.
    It was designed to trap carbon from diesel engines, using sound to clump the very fine carbon particles to allow easier filtering.
    Maybe there could be a future use for coffee roasters.
    Barry
    Jun 2009
    4
    I found this aftermarket catalytic combuster that might do the job in particular if it was fitted at the chaff collector exit. I have attached the link.
    http://www.woodmanspartsplus.com/4850/20455/Replacement-Catalytic-Combusters/Catalytic-Add--On-Stove-Damper.html
    Feb 2008
    1,339
    Quote Originally Posted by 62656370727A746362110 link=1282127521/7#7 date=1282309676
    Yes, following some discussions with the OT and my initial research into catalytic converters make me think these might be a suitable and cost effective option.
    The two issues I see at this point are that:
    a) catalytic converters need a certain amount of heat to trigger the reaction, which could I think be overcome with the addition of a PID and electric element, and,
    b) they may cause restriction to the airflow.
    At this point Im really curious, researching furiously, and willing to invest some money in the idea!
    Jul 2008
    Port Fairy
    2,993
    Some info here on Catalytic converters and a non flame process from Probat Burns toward the end of the doc also some info on running costs comparisons http://www.ncausa.org/files/public/M...e_Roasting.pdf
    Water curtain and scrubber unit with pics http://www.coffeed.com/viewtopic.php?f=16&t=2293
    Jun 2009
    4
    pid and electric element sounds like the go, 200deg c will do it which 392 deg f
    Jul 2008
    Port Fairy
    2,993
    Bump sort of.
    I have been looking a bit more seriously into commercial catalytic converters with a few extras at $11-12k USD compared to a similar size afterburner at $7k USD but with a huge saving in gas or electricity (both options available for the Cat). The system I have been looking at allows the recirculation of the scrubbed heated air back into the roaster to reduce heating costs further.
    So looks like the days of the small afterburners if required might be numbered?
    Feb 2008
    1,339
    Quote Originally Posted by 34333738303A2F3F3831560 link=1282127521/11#11 date=1289026777
    Nope.
    Nothing, I repeat...nothing, will work as effectively or efficiently as an afterburner.
    Jul 2008
    Port Fairy
    2,993
    Quote Originally Posted by 0315101001030F06060505600 link=1282127522/12#12 date=1289029386
    I gather that is purely on a clean point of view and not on a running cost basis? Interested on what info you have on this.
    On a smaller example a reduction of about 70%+ of the gas usage was put up over using an afterburner.
    As the cost of gas and energy generally rises costs may win out over any slight disadvantage (havent seen any figures on exhaust quality of one to another) with not using an afterburner.
    Senior Member Gavisconi007's Avatar
    Mar 2014
    592
    Electrostatic Precipitator for smoke and odour control
    Quote Originally Posted by beanflying View Post
    This thread seems to have gone nowhere, but looking at pricing and sizes, it appears to me that an electrostatic precipitator with an ozone final stage would be the best solution for a small roaster. Has anyone used one, and if so, what are the pros and cons?
    Dec 2013
    5
    hey guys, activated carbon is great at absorbing odour causing molecules, but it does actually burn with enough heat.
    I used to use actived carbon to mop up any extra ozone from cleaning up smelly air - till I met a Frenchman with black dots embedded in his face. The black dots were tiny lumps of activated carbon from a filter that caught fire and exploded. He was luck to survive the explosion but lives covered in black dots.
    What out using activated carbon in hot air applications.
    Dec 2013
    5
    Behmor Coffee Roaster
    Has anyone considered a wet scrubber? These are cheap and cheery and can knock down a lot of odour and fine powders...much cheaper than an ESP
    Dimal likes this.
  1. Replies: 33
    Last Post: 26th August 2012, 03:17 PM
  2. Carbon Fiber Rancilio Silvia
    By Firepower in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 13th July 2010, 04:47 PM
  3. Is this folder still active?
    By ed_vinas in forum Art Gallery
    Last Post: 2nd February 2005, 01:10 PM
