Results 1 to 8 of 8
Thread: First Behmor Roast
    caffeinated lemoo's Avatar
    Oct 2011
    Perth, WA
    330
    First Behmor Roast
    first ever roast ever on a behmor :)
    350 of peru on 1lb p2 B
    pulled after 12.5 mins in just on the door of sc for a lighter roast
    only problem for me is trying to see what roast level that is exactly
    8 maybe?
    Senior Member sidewayss's Avatar
    Jun 2010
    Perth, Western Australia.
    1,434
    Re: First Behmor Roast
    Congrats on your maiden roast lemoo. :)
    Looks like C8 or 9, but it looks like a great roast from where i see.
    The Peru is a great bean to learn on.
    Trust you have plenty of beans to play with. :D
    Gary at G
    Senior Member brettreaby's Avatar
    Oct 2011
    267
    i also had my first roast monday 9th evening with these Peru: 430G, P1,D ( extending the time to max 22.30 )and got a similar result although Bemor timed out before i heard the 2nd crack, so i wasnt sure if they were under-done.
    Anyway first taste this morning ( 2.5 days after roast) and they were fabulous!
    I also have done last night a smaller batch 350 g starting weight and got to 2nd crack and a cs9+ colour so interesting to compare the flavour of them.
    seems to me you cant really go past 350g if you want the option of a really dark roast with these beans.
    Oct 2011
    Perth, WA
    330
    hmm just noticed something interesting
    was putting a roast through P2/B on the behmor
    according to the manual it says that p2 ramps up to 100% power to about 60% of the time and then drops the power back for about 30% of time
    and for the last 10% of time ramps power back up to 100%
    does this mean that the back elements should turn back on?
    I was datalogging the temp change as well and noticed no increase in temperature before the program ended and went into the cooling cycle
    the temperature drop was accurate @ 60% of time in but just didnt seem to increase from there and just slowly coasted to lower temps all the way to the end?
    Senior Member Philby1981's Avatar
    Jun 2009
    155
    I wasnt datalogging lemoo but noticed the same thing. Expected elements to come back on at the end..
    Oct 2011
    Perth, WA
    330
    hmm thats interesting
    i wonder if anyone else has had the same experience?
    or if its meant to be that way?
    Oct 2011
    267
    Im new to this roasting caper but pretty sure it is meant to be that way: i suspect there is a lower temp at which the main element re-ignites. ( maybe less than 100C as it measures by its thermistor on the outside of the oven wall.).
    The basic problem seems to be getting to second crack with 400+ grams.
    The answer is to use less beans- max 350g i reckon, plus extend the time to max available.
    All speculation by me at this stage... no doubt Andy can confirm....
    Quote Originally Posted by 545D555757380 link=1326239866/5#5 date=1326843007
    Oct 2011
    Perth, WA
    330
    Behmor Coffee Roaster
    thanks for the input on the topic brettly
    yeah hopefully we will hear from someone that knows for sure
  1. Replies: 81
    Last Post: 6th September 2013, 10:36 AM
  2. Behmor First Roast
    By Gum in forum Roasters
    Last Post: 14th September 2012, 01:56 PM
  3. My First Behmor Roast
    By JJJ in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 18th December 2010, 03:16 AM
  4. My First Roast with Behmor
    By mtarros in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 22nd November 2010, 04:24 PM
