Results 1 to 12 of 12
Thread: Heat & Food safe supper glue
    Oct 2008
    19
    Hi Fellow Roasters.
    The mixing paddle in my bread maker keeps working its way off mid roast. I would have picked it up and thrown it in the bin if it wasnt so hot. I just wasted 400 grams of good beans!!!
    Can anyone point me in the direction of a heat & food safe super glue?
    Thanks.
    Mike
    May 2008
    4,275
    Re: Heat & Food safe supper glue
    From bread makers I have seen, paddles are usually held on by a cir-clip. If your BM has one, perhaps its broken or needs to be replaced.
    I wouldnt be gluing it back on.
    Senior Member artman's Avatar
    Jun 2006
    2,476
    Same thing happened to me last roast, only I wasted 620grams :(
    I plan to drill and tap the side of the paddle through to the hole where the spindle sits and insert a grub screw/bolt to secure it.
    Nov 2011
    120
    Can recommend this FDA approved Lottie glue. It is used in Pharma industry
    http://www.henkelna.com/industrial/food-beverage-threadlocker-loctite-2046-8063.htm
    Mar 2004
    Internet
    17,543
    ...whatever industry it was has obviously spammed us in the past as the "word fudge" got your post.
    ;D
    Sep 2011
    395
    Would hazard a guess it has to do with legal chemicals that require some sort of doctors report to obtain?
    Nov 2011
    120
    Yeah Andy it doesnt like the drug manufacturing industry word.... ;). At least I work in Australias largest opium processing factory & it makes things interesting.... :D
    Aug 2008
    Millthorpe NSW
    2,052
    I havent ever had the paddle come off mid-roast, but it has kept dropping into the cooler which is pretty annoying. I considered the grub screw option too, but thought Id struggle drilling the (most likely) hardened shaft without a drill press.
    So yesterday I just sacrificed the metal clip from the lid of a felt tip pen, cut a 15mm length, and used it as a shim against the flat keyway - and low & behold - a perfect press fit! Only required light taps from a hammer to slide it on, and its not coming off again in a hurry!
    Just be sure to support the stirrer assembly underneath, or you can tap out the whole thing through the teflon bush…
    Now lets see if it all expands at different rates and cracks the paddle… ;D
    Matt
    Oct 2008
    19
    Thanks guys. I tried DesigningByCoffees idea. I was only able to get a metal paper clip down in there and hammer the paddle back into place.
    Well see how long it lasts.
    Jun 2006
    2,476
    Good thinking re the shim, quicker and easier to my idea. I wasnt meaning to drill into the shaft, just the paddle (part that surrounds the shaft), which looks to be aluminium, and as you screw in the bolt/grub screw it presses against the side of the shaft.
    Aug 2008
    Millthorpe NSW
    2,052
    Quote Originally Posted by 2C3F39202C234D0 link=1327288321/9#9 date=1327370289
    Ahhhh yes - that would work too. I was thinking of going into the top of the shaft. But there seems to be plenty of meat in the paddle unit for tapping the hole through the side for the grub… good plan :)
    Matt
    May 2008
    52
    Behmor Coffee Roaster
    Had the same problem with mine a couple of years back, drilled through the paddle and shaft and put a split pin through it, has not moved since. ;)
  1. Is it safe ?
    By elitearies in forum Brewing Equipment (non-machine specific)
    Last Post: 14th December 2008, 08:24 PM
  2. Roaster Soupcan Mod - Glue/plastic problems
    By ezralimm in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 6th September 2008, 03:38 PM
