Results 1 to 9 of 9
Thread: Tips for roasting Yemen Mocha Sanaani?
    Aug 2010
    45
    Did some today, corretto.
    Seemed to get there a bit too quick. Result, a bit uneven.
    Anything special that needs to be considered when doing these small beans?
    Cheers.
    Oct 2006
    504
    Re: Tips for roasting Yemen Mocha Sanaani?
    ive had similar issues with my behmor and seem to find one of the profiles with the slower ramp up seems to put things back on track for me
    Mar 2012
    4
    Yemeni beans will always be uneven no matter how you roast them. They are a mix of ripe, underripe and overripe beans. Just dont worry about them being uneven, go ahead and do a taste test after 2-3 ds of rest. They usually taste wonderful. The unevenness just add a melanges effect.
    Aug 2010
    45
    Sat for 5 days and into the grinder this morning.
    Smooth as silk. Absolutely brilliant. A different class of coffee. Worth the sheckles.
    But, way too good to pour milk into it. Back to short blacks whilst this stash holds out.
    And cheers for the feedback re roasting these lil beauties.
    Feb 2012
    30
    Hello! I am having the same problem as weby had. Thankfully, I got some great suggestions here. I hope more discussions will further help me. Thanks!
    Sep 2009
    134
    Quote Originally Posted by 213334342F560 link=1331202092/0#0 date=1331202092
    Cheers.
    How long did your roast take in the end? I use a corretto setup as well and Im still trying to figure out what is a good temperature ramp and roast time ..
    Aug 2010
    45
    Quote Originally Posted by 4A575A4D4A4D380 link=1331202092/5#5 date=1333358933
    Cheers.
    All up about 16 minutes - C9/C10.
    A bit hit and miss with these beans. Main problem seems to be lack of audible crack. Ive been dumping when smoke pours off top, colour appears about right and some faint hint of second crack.
    Also, mine are tending to taste better after 7+ days rest.
    Senior Member Beanz.'s Avatar
    Apr 2009
    229
    This is one of my favourite beans but find controling the roast after first crack requires careful monitoring. I like the corretto for this bean as I have far more control in the last few minutes.
    I have run the attached profile a few times and I am very satisfied with the results in the cup, great espresso and short machiattos. I have run longer times following !C but find it gets away so quickly that I prefer to pull earlier rather than risk a darker roast
    Dec 2010
    Atlanta, GA USA
    54
    Behmor Coffee Roaster
    Quote Originally Posted by 3A223825393E332825234A0 link=1331202092/1#1 date=1331205057
    I initially tried using P3 on my Behmor, and the beans tasted under-roasted. Hard to describe, the flavors were narrow / grassy / undeveloped.
    Based on feedback from other Behmor users, I changed to using P1. This gave me great results.
  1. More Mocha/Yemen ?!?!??!?
    By Big_Steve in forum General Coffee Related...
    Last Post: 19th July 2009, 05:19 PM
  2. Any roasting tips? Decaf Mocha Java
    By -Alchemist- in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 26th January 2008, 02:21 PM
  3. Roasting challenges with Yemen Mocha Ismaili
    By mauricem in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 3rd November 2004, 09:17 PM
