Results 1 to 8 of 8
Thread: My first roast
    Jan 2009
    82
    My first roast
    Recently purchased a Behmor and this morning had my first go at roasting coffee.
    315g Peru Ceja de Selva Estate, settings were 1lb/B/P2
    1st crack at 5:00 and silent by 3:00, 2nd crack at 0:40 at which time I hit the cooling button, after 1 min of cooling I opened the door ajar.
    Turned out around CS9, basically no smoke at any stage, next time ill use 1lb/C/P2 to try avoid the heat ramp up between 1st and 2nd crack.
    Tasting notes to follow in a few days ;)
    Senior Member DavidW1960's Avatar
    Jan 2012
    Kariong NSW
    545
    Re: My first roast
    That is a really early first crack! On 1lb p2 c I get first crack at around 13 mins.
    Senior Member timmyc's Avatar
    Feb 2011
    Edithvale, Melbourne AUS
    223
    Re: My first roast
    Quote Originally Posted by 4D687F606D5E38303F39090 link=1337991731/1#1 date=1338084232
    I believe he means 5 minutes remaining - which sounds about right to me ;)
    Jan 2012
    Kariong NSW
    545
    Re: My first roast
    Ah ok. Im not familiar with 1lb P2 B setting. For me first crqack is around 10 mins remaining..
    Jan 2009
    82
    Re: My first roast
    Yes times stated was the remaining duration for that program.
    Translated this means 1st crack after 15min and 2nd crack after 19:20.
    The only difference between the "B" setting and the "C" setting if you select 1lb/P2 is the duration, which goes from 20:00 to 22:30 if the manual is correct.
    Senior Member coffeechris's Avatar
    Jul 2011
    727
    Re: My first roast
    Very even roast for your first try. This bean is a good starting point and this looks good from the photo.
    Good stuff :)
    Jan 2012
    Kariong NSW
    545
    Re: My first roast
    "C" goes to 21:30 with 1lb P2 setting. But yeah - you roast looks nice!
    Jan 2009
    82
    Re: My first roast
    Behmor Coffee Roaster
    Some brief tasting notes...
    Balanced acidity with cocoa and caramel notes, makes a pleasant latte, a bit lacking in body, loads of crema but collapses fast.
    The mrs said it was the best piccolo she has had in a while 5 days post roast.
  1. Replies: 81
    Last Post: 6th September 2013, 10:36 AM
  2. Cafe Startup Question: Self-Roast or Outsource Roast?
    By mirx in forum General Coffee Related...
    Last Post: 30th May 2011, 01:14 PM
  3. size of roast effects on  Gene Cafe roast tim
    By herbie in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st April 2007, 10:30 PM
  4. single roast...3/4 roast...double roast
    By lucinda in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 5th January 2007, 04:47 PM
