Results 1 to 15 of 15
Thread: First + Second try roasting. 1C and 2C very late.
    Apr 2012
    11
    First + Second try roasting. first crack and second crack very late.
    Hi guys,
    First time poster and first time roaster here* ;D
    Ive been a long time reader on this forum but I have finally taken the plunge in terms of home roasting because of the reported happiness it seems to bring to all home roasters. :D
    My setup is a little strange because Ive tried to keep my roasting experience low cost, and also hands on to maximise the fun. I use a Heat Gun on a cast iron wok, with a wok turner to toss the beans.
    With the 2 batches I have roasted (500g) batches; one being a PNG and the other a Columbian I got from BeanBay; and they have both tasted really good. The first one was a little light on the roast but the second one was pretty good. They both exhibit the characteristics I expect of the region with nice subtle flavors as well.
    The way I do it, I keep the heat gun about 2-3cm away from the beans and toss the beans around gently throughout the roast. I start off the heatgun at 300 degrees for about 4 minutes then pump it up to 600 degrees for the remainder of the roast.
    My process makes a lot of noise as metal clangs on metal so I dont even hear the first crack so I dont know what time it happens. But second crack is evident and usually starts around 45 minutes into the roast and settles down around 50 minutes into the roast.
    In my opinion, Im pretty happy about the taste of the roasts but I was wondering if there are any issues with having such a long roast time? I dont really understand the reasoning behind having the ballpark targets of roast timings.
    thanks for any input you guys can provide.
    P.S.: Ive attached a few photos too!
    caffeinated lemoo's Avatar
    Oct 2011
    Perth, WA
    330
    Re: First + Second try roasting. first crack and second crack very late.
    hmm, try to get a stand for your heat gun.
    id say that would be the first step if you are just holding it with your arm I had a laugh
    you could probably fashion one up with scraps of material and some duct tape to keep your cost down
    Apr 2012
    11
    Thank lemoo for the advice.
    Ill build a stand of some sort once I cant be bothered holding it anymore :) (for now the excitement of roasting still keeps my hands from tiring)
    Jul 2011
    73
    2 things spring to mind.
    Roast in smaller batches.
    Make a lid. A round saucepan lid, remove the central handle, holesaw a hole big enough to fit the nozzle of the heatgun through, and hold it in place with a hose clamp.
    But if youre gonna go to Vinnies/Salvos to scrounge a saucepan lid, see if you can score a suitable breadmaker (search on here for Coretto). I scored the one Im using for $15.
    Amanda
    Dec 2004
    Earth!
    15,663
    Welcome to CS Pernguin.
    Quote Originally Posted by 4752455950425E59370 link=1338786311/0#0 date=1338786311
    Are you sure its 2nd crack youre hearing and not 1st? 1st crack is normally significantly louder than 2nd crack.
    It sounds like youre baking the beans rather than roasting them. Try aiming for a total roast time of 15-20 minutes, 25 at the outside. With the long roasting times like youre talking about the beans will taste flat compared to ones roasted in 20 minutes.
    Given your method you probably wont be able to achieve the shorter times. Using a heat gun with the beans in a wok most of the wok is cold which sucks the heat out of the beans so the beans are constantly going through a heating/cooling cycle as they move in and out of the hot air stream from the heat gun. To achieve the best flavor the beans need to be constantly increasing in temp with no cooling off during the roast. Using a wok (Especially a large cast iron one.) with a heat gun as your heat source it will be virtually impossible to maintain an even and constantly increasing temperature through-out the bean mass. The larger the bean mass the harder it will be. If you want to stick with your current setup try decreasing the bean mass until you reach a point where the roast can finish in that 20 minute time frame. If you want to stick with the larger bean quantities an option would be to put a burner under the wok to heat it. If you have a big enough burner you could probably even do away with the heat gun.
    I would second Commandas comment to go the breadmaker (Called a Corretto on here in honor of the user who came up with the method.) route. You can maintain your large batch size and have a much more controllable and timely roast.
    Java "Enjoy the journey!" phile
    Apr 2012
    11
    Thanks for the advice Javaphile!
    I get what you mean about the wok sucking up all the heat.
    Ill experiment with it another time but if I cant get it in the ballpark maybe Ill look for a breadmaker :)
    Im not 100% sure Im hearing 2nd crack but I always thought second crack sounded like pop corn popping... and thats what I hear 40+ minutes in..
    Senior Member coffeechris's Avatar
    Jul 2011
    727
    Hi Pernguin,
    10 Points for effort holding the heat gun that long, i tried a few ways before i found a really cheap bread maker. I constructed a makeshift stand to hold the heat gun. The beans turn out pretty good.
    Good luck with whatever way you go, but i would suggest getting a bread maker :)
    Senior Member saoye's Avatar
    Jul 2011
    Adelaide
    1,006
    Look at classifieds for a second hand bread maker and get started with a corretto setup. 40 mins roast and the roast color is still around cs8 Id say its baked. A 500g roast as a first timer is risky so Id keep it to smaller batches to minimize the risk of a bad roast. Maybe even try a target popper and taste the difference between a baked roast and one thats not baked.
    Dec 2004
    Earth!
    15,663
    Quote Originally Posted by 1104130F0614080F610 link=1338786311/5#5 date=1339056085
    That sounds more like first crack. Second crack sounds more like Rice Crispies or the crinkling of Saran Wrap when wadded up. In a typical roast at 1st crack the beans change from a light golden brown to a medium brown. At 2nd crack the smoke coming off the beans will dramatically increase and their color will head towards black. These color changes may not correspond to your roasts as its very likely that the outside of your beans are being baked in the direct blast of the heat gun and changing colors while the inside of the beans are not being roasted until much later.
    I think youll be very happy going that route. Its an inexpensive path and one that gives you great control over the roast and with practice and experience allows you to produce beans as good as you can get from a professional roaster.
    Java "Welcome to the ranks!" phile
    Apr 2012
    11
    Quote Originally Posted by 6C6069696A6A6C677D667C0F0 link=1338786311/6#6 date=1339061842
    I had a laugh it just had to make sure my arm was fully stretched out so there was my muscles needed next to no effort :)
    And thanks for all the advice guys...
    Ive looked into getting a second hand bread maker...
    Seems pretty reasonable price wise...
    Will try another batch soon and update on my progress :)
    Jul 2011
    727
    If you get a bread maker, you will think why didnt i do this sooner??? Mind you all respect to you if your one of these people who likes to come up with an idea which is a little bit different.
    Either way roasting coffee is fun and addictive :)
    Apr 2012
    11
    Quote Originally Posted by 676B62626161676C766D77040 link=1338786311/10#10 date=1339291922
    haha, I guess I am in some ways one of those "people"...
    But i only stick to my "something different" if it turns out to be something better..
    I just like to play around with things I have already :)
    p.s.: just waiting on people on gumtree to respond to me so I can get the breadmaker :)
    Jul 2011
    727
    Gumtree is where i started to look for a a bread maker, i then put a notice up at work and waited. Then all of a sudden i mentioned it too a good friend of mine who said... "I have one and i dont use it so please have it". I guess what im trying to say is also ask those who you think wouldnt have one, cause sometimes they do :)
    The heat gun was the expensive part for me which is still going strong. I brought it from total tools we have here in Melbourne. IT only cost me $49.
    Nov 2010
    369
    could you use some bottom heat such as a gas burner to speed things up?
    Apr 2012
    11
    Behmor Coffee Roaster
    Quote Originally Posted by 373C3D0C3D323A213D530 link=1338786311/13#13 date=1339678257
    Interestingly, I tried another batch on the wok while still waiting on a bread maker... (because I ran out of coffee)
    This time I brought the wok up to about 180 degrees on the stove before I put the beans in...
    I got to a "TRUE" second crack in about 35 minutes...
    which is way earlier than I would have without heating it up...
    but it was harder to control and my roast was the slightest bit uneven...
    Taste wise, still very happy with the results... :)
  1. Where to buy cafe late glasses?
    By branjie in forum General Coffee Related...
    Last Post: 30th September 2009, 01:20 PM
  2. late night coffee
    By bintang86 in forum General Coffee Related...
    Last Post: 14th May 2007, 01:25 PM
